03-08-2015 07:29 AM - edited 03-01-2019 12:03 PM
HI
In the project , I have two UCS 5108 Blade Chassis(AC), the IO module is 2108,and FI is 6120XP configuational
UCSM version is 2.1(3a)
My UCSM can't discover the Chassis
the error logging is
Code ID
F0402 4545035 Chassis has invaild FRV
F0400 4545037 CHassis connectivity configuational is unknowledge
F0543 4545034 IOM4/1(A) connectivity was unknowledge
Is the 2108 too new,then my old FI can't support?
03-08-2015 03:15 PM
you probably mean 2208 not 2108 ?
- How many links do you have between IOM and 6120 ?
- is this happening with both chassis
- is it happening with only IOM per chassis or both IOM ?
- did you ack the chassis, so it discovers the topology ?
03-09-2015 09:15 AM
From what I can see you have the following chassis PID: UCSB-5108-AC2 if this is the case the reason it won't discover is because your UCSM is not running the minimum firmware required by this chassis which is 2.2(1b). if you upgrade your firmware to that version your chassis will discover.
see release notes below its under table 5. If you have an chassis with PID: N20-C6508 then make sure to have at least the same number of IOM links defined in your link policy.
UCSM 2.2 Release Notes
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/ucs_2_2_rn.html
