UCS B200M3, 3750G Switch connectivity oddness
Chris Hibbert
Morning All,
Hoping someone can help, I have a strange situation that occurs with my new UCS installation.
Configuration is:
UCS Chassis connected to a pair of 6248UP Fabric Interconnects, using 2208XP IO Modules.
I connect from this to a distribution 3750 stack, I have configured 2 etherchannels on the 3750 stack, and on the UCS Manager, these are configured to pass all the relevant VLAN's, I have three blades (B200M3) installed into the chassis with VMWare ESXI 5 installed.
Once they have all been set up they can communicate both ways to and from the network without problem, both the vmware networks and the LAN.
Overnight (without any changes) 2 of the blades (slots 2 and 3) stop communicating to the network. I can get them working again by making a few changes to the network settings and all will be ok until the next day.
I am at a loss as to what can be causing this.
Any help would be great.
Chris
That should fix your issue.  UCS will not forward unknown unicast, so if a UCS blade/VM MAC address ages out on your 3750's, the outside world will not be able to reach it.  Under normal/production operation servers are normally chatty enough to keep the aging timers from depleting so you'll likely only see this at this time during the install when there are few/no VMs sending/receiving.  Another option is to increase the aging timers on the 3750.
Let me know it goes tomorrow.
Robert
17 Replies 17
Robert Burns
Please connect to the UCSM CLI and collect the following output:
connect nxos
show cdp neighbor
show port-c sum
show int trunk
Paste here.
Roberrt
hi, Thanks for your reply, please see the information requsted
trl-secure-A(nxos)# show cdp neighbors
Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater,
                  V - VoIP-Phone, D - Remotely-Managed-Device,
                  s - Supports-STP-Dispute
Device ID              Local Intrfce   Hldtme  Capability  Platform      Port ID
trl-secure-A(nxos)# show port
port            port-channel    port-profile    port-security
trl-secure-A(nxos)# show port-channel  summary
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
Group Port-       Type     Protocol  Member Ports
      Channel
7     Po7(SU)     Eth      LACP      Eth1/27(P)   Eth1/28(P)
1284  Po1284(SU)  Eth      NONE      Eth1/1/5(P)  Eth1/1/7(P)
1285  Po1285(SU)  Eth      NONE      Eth1/1/6(P)  Eth1/1/8(P)
1286  Po1286(SU)  Eth      NONE      Eth1/1/1(P)  Eth1/1/3(P)
1287  Po1287(SU)  Eth      NONE      Eth1/1/2(P)  Eth1/1/4(P)
1290  Po1290(SU)  Eth      NONE      Eth1/1/9(P)  Eth1/1/11(P)
1291  Po1291(SU)  Eth      NONE      Eth1/1/10(P)  Eth1/1/12(P)
trl-secure-A(nxos)# show in
in-order-guarantee   incompatibility      install              interface            inventory
trl-secure-A(nxos)# show interface tr
transceiver   trunk
trl-secure-A(nxos)# show interface trunk
Port          Native  Status        Port
              Vlan                  Channel
Eth1/15       1       trunking      --
Eth1/27       1       trnk-bndl     Po7
Eth1/28       1       trnk-bndl     Po7
Po7           1       trunking      --
Veth693       2       trunking      --
Veth698       1       trunking      --
Veth699       1       trunking      --
Veth701       2       trunking      --
Veth703       1       trunking      --
Veth705       1       trunking      --
Veth707       2       trunking      --
Veth709       1       trunking      --
Veth711       1       trunking      --
Eth1/1/33     1       trunking      --
Port          Vlans Allowed on Trunk
Eth1/15       1-2,5,200
Eth1/27       1-2,5,200
Eth1/28       1-2,5,200
Po7           1-2,5,200
Veth693       2
Veth698       1
Veth699       2,200
Veth701       2
Veth703       1
Veth705       2,200
Veth707       2
Veth709       1
Veth711       2,200
Eth1/1/33     1-2,5,200,4044,4047-4049
Port          Vlans Err-disabled on Trunk
Eth1/15       none
Eth1/27       none
Eth1/28       none
Po7           none
Veth693       none
Veth698       none
Veth699       none
Veth701       none
Veth703       none
Veth705       none
Veth707       none
Veth709       none
Veth711       none
Eth1/1/33     none
Port          STP Forwarding
Eth1/15       1-2,5,200
Eth1/27       none
Eth1/28       none
Po7           1-2,5,200
Veth693       2
Veth698       1
Veth699       2,200
Veth701       2
Veth703       1
Veth705       2,200
Veth707       2
Veth709       1
Veth711       2,200
Port          Vlans in spanning tree forwarding state and not pruned
Eth1/15       --
Eth1/27       --
Eth1/28       --
Po7           --
Veth693       --
Veth698       --
Veth699       --
Veth701       --
Veth703       --
Veth705       --
Veth707       --
Veth709       --
Veth711       --
Eth1/1/33     --
trl-secure-A(nxos)#
Do you have CDP enabled on the 3750 stack interfaces?  No output in the show CDP neighbors.
I'd also like to see the interface config for the 3750 ports (both Port Channel and member interfaces).
show run int x/y
show run int po x
Robert
Thanks again, no CDP isn't enabled by default on this one, I have enabled it to facilitate a fix.
Here's the info.
Firstly the Neighbors report
U12CoreRed.trlsecure.l Eth1/27         124     R S I       WS-C3750G-24T Gig1/0/15
U12CoreRed.trlsecure.l Eth1/28         125     R S I       WS-C3750G-24T Gig2/0/18
trl-secure-A(nxos)#
Port-channel 7 Info:
U12CoreRed#show int port-channel 7
Port-channel7 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 0022.916c.7492 (bia 0022.916c.7492)
  Description: UBS FabA
  MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is unknown
  input flow-control is off, output flow-control is unsupported
  Members in this channel: Gi1/0/15 Gi2/0/18
  Last input never, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 3000 bits/sec, 4 packets/sec
     3850680 packets input, 3822146418 bytes, 0 no buffer
     Received 254378 broadcasts (172854 multicasts)
     0 watchdog, 172854 multicast, 0 pause input
     14766733 packets output, 7313073697 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
U12CoreRed#show int g1/0/15
GigabitEthernet1/0/15 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0022.916c.730f (bia 0022.916c.730f)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  Last input 00:00:26, output 00:00:04, output hang never
  5 minute output rate 2000 bits/sec, 4 packets/sec
     234954 packets input, 99988405 bytes, 0 no buffer
     Received 166587 broadcasts (86599 multicasts)
     0 watchdog, 86599 multicast, 0 pause input
     6851946 packets output, 600462501 bytes, 0 underruns
     54387 unknown protocol drops
U12CoreRed#show int g2/0/18
GigabitEthernet2/0/18 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0022.916c.7492 (bia 0022.916c.7492)
  Last input 00:00:12, output 00:00:33, output hang never
     3615893 packets input, 3722198373 bytes, 0 no buffer
     Received 87958 broadcasts (86411 multicasts)
     0 watchdog, 86411 multicast, 0 pause input
     7924984 packets output, 6714119929 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
Port-channel 8 info
U12CoreRed#show int port-channel 8
Port-channel8 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is c8f9.f9e3.118f (bia c8f9.f9e3.118f)
  Description: UBS FabB
  Members in this channel: Gi1/0/16 Gi3/0/15
  5 minute output rate 4000 bits/sec, 6 packets/sec
     212497 packets input, 65688627 bytes, 0 no buffer
     Received 182191 broadcasts (173635 multicasts)
     0 watchdog, 173635 multicast, 0 pause input
     9493059 packets output, 930235990 bytes, 0 underruns
U12CoreRed#show int g1/0/16
GigabitEthernet1/0/16 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0022.916c.7310 (bia 0022.916c.7310)
  Last input 00:00:13, output 00:00:01, output hang never
  5 minute output rate 2000 bits/sec, 3 packets/sec
     117044 packets input, 32002148 bytes, 0 no buffer
     Received 95561 broadcasts (87266 multicasts)
     0 watchdog, 87266 multicast, 0 pause input
     5234624 packets output, 480601569 bytes, 0 underruns
     54421 unknown protocol drops
U12CoreRed#show int g3/0/15
GigabitEthernet3/0/15 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is c8f9.f9e3.118f (bia c8f9.f9e3.118f)
  Last input 00:00:20, output 00:00:21, output hang never
  5 minute output rate 1000 bits/sec, 1 packets/sec
     95525 packets input, 33704654 bytes, 0 no buffer
     Received 86702 broadcasts (86441 multicasts)
     0 watchdog, 86441 multicast, 0 pause input
     4262744 packets output, 450231499 bytes, 0 underruns
I need the "show run int x/y" for the interfaces, not the "show int x/y"
Robert
oops
please find the running config for the interfaces. thanks again.
U12CoreRed#show run interface g1/0/15
Building configuration...
Current configuration : 191 bytes
interface GigabitEthernet1/0/15
switchport trunk allowed vlan 2,5,200
switchport mode trunk
channel-protocol lacp
channel-group 7 mode active
end
U12CoreRed#show run interface g2/0/18
interface GigabitEthernet2/0/18
end
U12CoreRed#show run interface g1/0/16
interface GigabitEthernet1/0/16
channel-group 8 mode active
end
U12CoreRed#show run interface g3/0/15
interface GigabitEthernet3/0/15
end
Enable Port Fast on the 3750 interfaces.  Not the main cause of your issue, but it's recommended when connected to UCS.  Should be something like "spanning-tree portfast edge trunk"
As for the connectivity issues, the only thing I can think of is the blades MAC address is aging out fo the 3750 MAC table.
What is the OS of the blades having the issue?
How are the blades OS interfaces configured? (Teamed together, or sepearate interfaces, vSwitch etc?)
When you say they lose connectivity, does that mean from the blade you can't ping outwards or from the network you can't reach your blades?
Robert
I have enabled the portfast as recommended.
The MAC addresses aging out might be a possible answer as the entry on the ARP table has cleared and only now that I try to ping the devices it shows as incomplete. is there a way of stopping it "aging out"?
The end O/S is ESXi, when the MAC address drops from the 3750 netiher end can ping each other (ie LAN to blade and blade to LAN).
The OS config is pairs of virtual nics (one from each Fabric) going to a vSwitch, vlan'd.
it's one of those annoying issues that just frustrates
There's a config problem somewhere.  The VM should always be able to ping outward, even if the "quiet VM" effect occurs and the MAC ages out, as soon as the VM initiates communication it will arp out for the gateway which should rebuild the ARP table upstream.
Are the vSwitch uplinks conifgured as default teaming options (Route based on virtual Port ID)? Hopefully you're not trying to use an IP Hash on the vSwitch uplinks, which will not work with UCS.
Robert
There are no VM's yet on the servers, all three are configured as the default image using the custom Cisco build for UCS servers. (i.e. Route based on virtual port, second nic in "standby adapter").
A simple restart of the management network is "usually" enough to kick the link back to life, the odd thing is that server 1 (slot 1) almost NEVER has this problem (only once and I believe it was misconfigured at the time). the servers in slot 2 and 3 are always getting this issue overnight.
I totally agree that the symptoms point to a misconfiguration, but the fact that server one is ok, and the others have profiles cloned from the first it's a real mystery.
Next time you get a host in this state - can you leave it like this?  That would be the best time to tshoot this.  From what I gather the UCS side sounds fine, I'd be sniffing around ESX/vSwitch for the config issue.  If you simply restart Mgmt service on the host to get things back online, that means UCS pinning and VLANs are all fine.  This is a host-side issue.
Any reason why you're using one NIC as standby and not using both A/A?
Robert
Hi Robert,
It was in this state the whole time during this, I think you might have hit the answer as on the third server rather than restarting the interface I simply ran the test from the management interface and this seemed to sort the problem immediately, I wonder if perhaps as these are in a default install, the servers are just too quiet and they simply age out.
I am installing a base windows server on all boxes as frankly they chat non stop - that might solve the issue and in a live environment the problem will simply not be there (ie heartbeats etc).
I'll update tomorrow when the servers have a quiet night and see if this doesn't cure the problem.
thanks a lot for all your help so far.
Chris
Robert
Well, this didn't entirely fix the problem - the management MAC's for the same 2 servers dropped again from the MAC table, however the virtual servers I added remained pingable, so I take that as a minor victory.
I have now added the ESX hosts to the cluster, I believe that the HA services will be more than enough to keep the MAC from aging.
I will close this down tomorrow assuming this has now resolved the issue.
Chris
