ā03-24-2011 05:59 AM - edited ā03-01-2019 09:51 AM
Hi all,
Our customer buy one server C200, and now he want to put RAID controler Adaptec ASR-2405, but this controler don't work.
Is there some reason that RAID controler is not working?
Can you give me some table with support third-party RAID controlers ?
Solved! Go to Solution.
ā03-24-2011 10:04 AM
Depending on the version of firmware choose the correct document from this link. This will tell you what Hardware and Software is supported.
http://www.cisco.com/en/US/products/ps10477/prod_technical_reference_list.html
