ucsd workflow issue
petercinvest
I create a workflow1: create vlan, I include four tasks to create vlan for switch1, switch2,switch3, switch4.
this workflow task are defined as component task. i define four fields vlan id (user input), vlan name (user input), device id, vdc id.
I then create another workflow2, inside workflow2, i already have one task, now i go to search menu and find my workflow1, then i drag and drop into workflow2, the strange thing happens, it pop me to enter input and output, and i find only vlan id and vlan name are listed, the other two field device id, vdc id is missing. is this the right behavior of ucsd? thanks
Kirk J
Greetings.
Do you actually need the VDC component actually involved if the mgmt interface is working/reachable on each of the VDCs?
Kirk...
