UCSM CLI output of inband management ip configuration
Dan Laden
When I look at the 'show configuration' output of the service profile on the CLI, i do not see the information of the inband configuration.  Where would I see this from the CLI.
UCSM 3.2.2
seems i needed the additional key word.
UCS3-A /org/service-profile # show mgmt-iface in-band detail expand
External Management Interface:
Mode: In Band
Ip V4 State: Static
Ip V6 State: None
Is Derived from Inband Profile: No
External Management Virtual LAN:
Network Name: vLan824
External Management Static IP:
IP Address: 192.168.128.3
Default Gateway: 192.168.128.1
Subnet: 255.255.240.0
Primary DNS IP: 0.0.0.0
Secondary DNS IP: 0.0.0.0
Wes Austin
You would scope to the service profile and run this command:
UCS-A# scope service-profile server 1/8
UCS-A /org/service-profile # show mgmt-iface in-band detail
This shows it is configured but no the explicit details that can be seen in the gui.
UCS3-A /org/service-profile # scope service-profile server 1/5
UCS3-A /org/service-profile # show config
enter service-profile HN1 instance
associate server 1/5
exit
Mode: In Band
Ip V4 State: Static
Ip V6 State: None
Mode: In Band
Ip V4 State: Static
Ip V6 State: None
