vNIC Failover with VIC 1340 & 2204 FEX / 6248 FI
MSL
Beginner
Beginner
We are trying to understand how vNIC failover happens with VIC 1340 & 2204 FEx. 2204 IOM VIC 1240 / 1340 with 2204 FExVIC 1240 / 1340 with 2204 FExwhich has 16 x 10GBs connected through the midplane which is 2 x 10GBs to each Blade server (M4); One connection goes to  VIC 1304 and another goes to mezzanine slot. So in case of a FI / FEX failure how the failover took place.
Thanks in advance
Evan Mickel
More information is necessary here, there are a number of different ways to configure redundancy but I will assume you are referencing a single vNIC with a group of VLANs that is set to Failover Enabled.
This would mean that at the UCS level when we detect a link down for any reason, the vNIC will lose the edge port on the switch that it is pinned to.  It will commence the process of re-pinning, it will analyze available uplinks to locate an uplink that satisfies ALL of the configured VLANs on the vNIC.  At which point it will pin to said uplink.
That is the basic process, please flesh out your question if that did not cover what you are looking for.
Thanks!
Recognize Your Peers
