on 12-12-2013 08:46 AM - edited on 05-26-2022 11:45 AM by dsoper
The following Cisco UCS Platform Emulators are available for download from Cisco:
CONFIGURATION IMPORT NOTE: Importing configuration backups (All, System, or Logical) taken from the UCS Platform Emulator (UCSPE) to physical UCS Manager domains is not recommended or supported by Cisco TAC. UCSPE backups should only be imported to UCSPE domains.
Cisco UCS Platform Emulator 4.2(2aPE1) - UCS 62xx/63xx/64xx Fabric Interconnect, C4200, S3260, Mini:
Downloads:
MD5 hashes for downloads:
Cisco dCloud Programmability Demo using the UCS Platform Emulator
Video demos of the Emulator
Cisco UCS Platform Emulator version 4.1(2cPE1):
Downloads:
Cisco UCS Platform Emulator version 4.0(4ePE1):
Downloads:
Cisco UCS Platform Emulator version 3.2(3ePE1):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 3.1(2ePE1):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 3.1(2bPE1) - UCS Classic, Mini, and C3260:
Downloads:
Documentation:
Cisco UCS Platform Emulator version 3.1(1ePE1) - UCS Classic, Mini, and M-Series:
Downloads:
Documentation:
Cisco UCS Platform Emulator version 3.0(2cPE1) - UCS Mini:
Downloads:
Documentation:
Cisco UCS Platform Emulator version 2.5(2aPE1) - UCS M-series:
Downloads:
Documentation:
Cisco UCS Platform Emulator version 2.2(5aPE1) - UCS Classic:
Downloads:
Documentation:
Cisco UCS Platform Emulator version 3.0(1cPE1):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 2.5(1aPE1) - UCS M-series:
Downloads:
Documentation:
Cisco UCS Platform Emulator version 2.2(4bPE1) - UCS Classic:
Downloads:
Documentation:
Cisco UCS Platform Emulator version 2.2(3aPE1) - UCS Classic:
Downloads:
Documentation:
Cisco UCS Platform Emulator version 2.2(2cPE1):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 2.2(1bPE1):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 2.1(3aPE1):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 2.1(2aPE1):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 2.1(1aPE3):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 2.0(1mPE1):
Downloads:
Cisco UCS Platform Emulator version 1.4(1aPE1):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 1.3(1aPE1):
Downloads:
I reuploaded a newer OVA on this. Can you retry it with the newest one I uploaded?
Where can we obtain support for UCSPE? Any community page? Experiencing all sorts of weird issues.
This is the place! Please post your question with details of the specific issues you are experiencing.
-Todd
The problem resolved itself, but not before I tried to start UCSPE with my new hardware configuration about 10 times. The default hardware configuration was sticking around and it would not load my new startup inventory. I rebooted and shutdown the UCSPE VM completely. Didn’t seem to make a difference. Have you come across this quirk before?
Also noticed that the blades are not reflecting all of the memory that has been added as well. Only 32GB or 16GB is showing up. Even though it accepted adding 16 and 6 x 16GB DIMMS.
Hello UCSPE Community,
I started with UCSPE V2.2.3aPE1. After install and launching UCSM and login with default user and password
it takes ab. 60 sec. and then the following error message appears:
Login Error: java.net.SocketTimeoutException: Read timed out
I´ve installed the lastest JRE 1.8.0_25-b18 (32 and 64 Bit) and use Firefox 31.2.0 ESR.
Any hint where to look further ?
problem fixed, it was related to initial setup of UCSPE, my fault. I did only configure a static IP on eth0.
After adding IP addresses for eth 1 and eth2 from the same subnet, login now works fine.
Hey Guys,
I have a customer that has identified a what we think is a problem with "Cisco UCS Platform Emulator version 3.0(1cPE1)". He would like to make changes to the startup configuration, eg. remove the C-series servers, reduced the B200M3 to 2, remove the VIC 1280's and change ram to 2 x 16GB DIMMS. Once anychange is made no matter how small and PE is saved and restarted we see no inventory at all. The 6324's appear as 6296's with no configuration options. The chassis has no inventory of configuration options.
Any idea's?
hi!
kindly help me! i get this message when am try to logging to the cisco UCS platform emulator
Login Error:
java.net.SocketTimeoutException:Read timed out
secharle Per the release notes for 3.0(1c) here the only servers supported are B200 M3, C220 M3 and C240 M4, sounds like you're breaking the emulator/trying to run it in an un-supported configuration. You're customer will have to use the 2.2(3a) version of the emulator until additional servers are supported.
Hope that helps!
ericwill Any ETA on a Emulator for 2.2(3c)? Looking to test/validate the "QPI snoop mode via Service Profile" settings for disabling Cluster-on-Die (CoD) for the new Intel E5-2660 v3 CPUs.
Is it not interesting, when I tried to change the clock manually !
cisco-ucspe /system/services # set clock Jan 06 2015 21 09 10
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these two things:
#1) Respect the privacy of others.
#2) Think before you type.
Password:
/usr/bin/sudo: /isan/bin/check_ntp_server.sh: command not found
Hello UCSPE Team,
is it possible to add the latest SP8 bundles to the Hardware Startup Bundles in UCSPE 2.2(3)a ?
thanks in advance for help and comments
Alfred
Is there a good quick start or tutorial for initial configuration using the emulator?
The guide to configuring the emulator itself is at the top of this page
As for configuring UCS Manager, the emulator is running a full version of UCSM, so any UCSM documentation is going to apply. Here are a couple of links:
UCS Manager Quick Start and Best Practices - Cisco UCS Manager Configuration Common Practices and Quick-Start Guide - Cisco
UCS Manager Configuration Guides and Examples - Cisco UCS Manager - Configure - Cisco
