09-25-2012 03:05 AM - edited 03-01-2019 10:38 AM
Hi All,
I've got my 1000v, VNMC and VSG installed and all registered with one another. I've created a simply policy in VNMC for testing of allow all. However, as soon as I assign it to my port-profile all traffic flow stops, yet nothing is ever hitting the policy engine.
This is my port profile:
port-profile type vethernet Test-VM
vmware port-group
switchport mode access
switchport access vlan 10
org root/TestTenant
vservice node VSG profile MyProfile
no shutdown
state enabled
And this is the output of "show vservice brief":
N1000v# show vservice brief
License Information
Type In-Use-Lic-Count UnLicensed-Mod
vsg 2
asa 0
Node Information
ID Name Type IP-Address Mode State Module
1 VSG vsg 10.1.20.99 v-20 Alive 3,
Path Information
Port Information
PortProfile:Test-VM
Org:root/TestTenant
Node:VSG(10.1.20.99) Profile(Id):MyProfile(3)
Veth Mod VM-Name vNIC IP-Address
1 3 2k3 1 10.1.10.200,
Show it appears the 1000v is happy it's received valid config for the VSG. Seems fine too, it has the rule:
firewall# show run rule
rule MyACL/PermitAll@root/TestTenant
action 10 permit
rule default/default-rule@root
action 10 permit
firewall# show run policy
Policy MyACLSet@root/TestTenant
rule MyACL/PermitAll@root/TestTenant order 201
Policy default@root
rule default/default-rule@root order 2
However... Nothing ever gets punted up for policy inspection:
firewall# show policy-engine stats
Policy Match Stats:
default@root : 0
default/default-rule@root : 0 (Permit)
NOT_APPLICABLE : 0 (Drop)
MyACLSet@root/TestTenant : 0
MyACL/PermitAll@root/TestTenant : 0 (Permit)
And I just can't fathom why.... any thoughts greatly appreciated!
09-25-2012 03:37 AM
OK, I'd forgotten my vPath config, I've added that:
vservice path vpath
node VSG profile MyProfile order 1
And the corresponding node config that was there before:
vservice node VSG type vsg
ip address 10.1.20.99
adjacency l2 vlan 20
fail-mode open
And traffic is flowing... but nothing is hitting the policy engine and nothing is denied even if I ask the rules to deny all.
Update: Traffic is flowing only thanks to the "fail open" setting in the VSG setting. That's why counters aren't going up, but I can't work out where I've gone wrong. Any thoughts?
09-25-2012 04:53 AM
OK, I'm confused...
If I use:
In my port-profile I can see packets on the 1000v matching:
N1000v# show vservice statistics
#VSN VLAN: 20, IP-ADDR: 10.1.20.99
Module: 3
#VPath Packet Statistics Ingress Egress Total
Total Seen 26 29 55
Policy Redirects 26 29 55
But no counters going up on the VSG and devices behind that port profile are unreachable.
If I switch to:
vservice path vpath
Module: 3
Total Seen 26 29 55
With the above vpath specified, I get just counters on fail-open going up, and nothing on the VSG again, but devices are reachable.
Any thoughts?
09-25-2012 06:12 AM
A small update...
Looking in VNMC, it says the VM/Port-Profile is associated with the IP "10.1.20.99" which it says is a non-existent firewall. That's the managment address of the VSG in question.
I then realised when you add the VSG to VNMC it asks you to create a data address, which I did and set to "10.1.20.100". I tried changing my node settings in the 1000v to use that address instead but it then says that the VSG is down (it's up when set to 10.1.20.99)
What is that data address used for? Or am I going in the wrong direction?
09-26-2012 12:14 PM
Paul,
From your port-profile config :
org root/TestTenant
You have used Security Profile MyProfile. In VNMC have you created Security Profile with same name - MyProfile(name is case sensitive), within Tenant- TestTenant associated with your compute firewall. All the Policy Sets will be part of this security profile.
To check other configurations look fine, From VSM can you get the output for following commands :
Module vem 3 execute vemcmd show vsn binding
Module vem 3 execute vemcmd show vsn config
07-24-2013 01:39 AM
Dear Skalje,
I am having the same issue. I have a ASA managed via ASDM with VService Node configuration iusing 10.1.1.1 for its inside address and for the VSG 10.1.1.2 for the data0 interface on the VSG. However the ASA is reachable but the VSG is not. Previously I had a the vservice node IP address for the VSG in the same subnet as the Management0 address of the Nexus1000v and this worked fine, with service chaining enable and applied to a port profile.
What I am trying to understand is does the VSM and VEM need to communicate with the VSG at Layer2 or Layer3. As the ASA does not seem to need to do, as the ASA is alive with the insdie IP set to 10.1.1.1?
Here is the output you request from the previous post?
gs2-cldnexus-01# Module vem 3 execute vemcmd show vsn binding
VSG Services Enabled | VSG Licenses Available 2
ASA Services Enabled | ASA Licenses Available 2
LTL PATH VSN SWBD IP P-TYPE P-ID
50 1 3 501 10.1.1.2 1 7
50 1 1 501 10.1.1.1 2 3
56 1 3 501 10.1.1.2 1 7
56 1 1 501 10.1.1.1 2 3
66 2 2 506 10.1.2.1 2 5
69 2 2 506 10.1.2.1 2 5
gs2-cldnexus-01#
gs2-cldnexus-01#
gs2-cldnexus-01# Module vem 3 execute vemcmd show vsn config
VSN# SWBD IP MAC LTLs VER VER-BITMAP
1 501 10.1.1.1 00:50:56:ba:1a:61 2 2 1,2
2 506 10.1.2.1 00:50:56:ba:76:8c 2 2 1,2
3 501 10.1.1.2 00:00:00:00:00:00 2 1 1
Also from show vservice brief
gs2-cldnexus-01# show vservice brief
License Information
vsg 2
asa 2
Node Information
1 CUST01-ASA asa 10.1.1.1 v-501 Alive 3,
2 CUST02-ASA asa 10.1.2.1 v-506 Alive 3,
3 CUST01-VSG-01 vsg 10.1.1.2 v-501 Unreach 3,
Path Information
Name:CUST01-Chain NumOfSvc:2 Mod:3,
Node Order Profile
CUST01-VSG-01 1 CUST01-Server-Compute-Profile
CUST01-ASA 2 Profile-CUST01-Server
Port Information
PortProfile:Profile-CUST01-Server
Org:root/CUST01
Path:CUST01-Chain
Node Profile(Id)
CUST01-VSG-01(10.1.1.2) CUST01-Server-Compute-Profile(7)
CUST01-ASA(10.1.1.1) Profile-CUST01-Server(3)
3 3 cust01-vm01 1 10.1.1.10
10 3 cust01-router01 3 10.1.1.254
PortProfile:Profile-CUST02-Server
Org:root/CUST02
Node:CUST02-ASA(10.1.2.1) Profile(Id):Profile-CUST02-Server(5)
5 3 cust02-vm01 1 10.1.2.10
12 3 cust02-router01 3 10.1.2.254
Darren Frowen
07-24-2013 07:29 AM
Hi All,
This issue is now resolved. Although I had defined the VSG security Profiles, and assigned the VSG to the Tennat. What I had failed to perform is the Assisgn to VSG in the same Window, seen at the top right hand corner.
It does appear that there is only a requirement for L2 or L3 communication between the VEM and the VSM. As long as you have that using Layer2 address for the VSG data interface or the ASA inside interface for the VSN config is fine, as I belience that the Tunnel created for the vPath communication is between the vmk on the VEM and the Mgmt of the VSM, mac in mac or UDP at L3.
Configuration now looks great and I have service chaining working perfectly;
gs2-cldnexus-01# sh vservice brief
License Information
vsg 2
asa 2
Node Information
1 CUST01-ASA-01 asa 10.1.1.1 v-501 Alive 3,
2 CUST02-ASA-01 asa 10.1.2.1 v-506 Alive 3,
3 CUST01-VSG-01 vsg 10.1.1.2 v-501 Alive 3,
4 CUST02-VSG-01 vsg 10.1.2.2 v-506 Alive 3,
Path Information
Name:CUST01-CHAIN NumOfSvc:2 Mod:3,
Node Order Profile
CUST01-VSG-01 1 CUST01-Server-Comp-Profile-01
CUST01-ASA-01 2 CUST01-Server-Edge-Profile-01
Name:CUST02-CHAIN NumOfSvc:2 Mod:3,
Node Order Profile
CUST02-VSG-01 1 CUST02-Server-Comp-Profile-01
CUST02-ASA-01 2 CUST02-Server-Edge-Profile-01
Port Information
PortProfile:CUST02-Server-Chained-Profile-01
Org:root/CUST02
Path:CUST02-CHAIN
Node Profile(Id)
CUST02-VSG-01(10.1.2.2) CUST02-Server-Comp-Profile-01(16)
CUST02-ASA-01(10.1.2.1) CUST02-Server-Edge-Profile-01(11)
5 3 cust02-vm01 1
PortProfile:CUST01-Server-Chained-Profile-01
Org:root/CUST01
Path:CUST01-CHAIN
Node Profile(Id)
CUST01-VSG-01(10.1.1.2) CUST01-Server-Comp-Profile-01(12)
CUST01-ASA-01(10.1.1.1) CUST01-Server-Edge-Profile-01(10)
3 3 cust01-vm01 1
Darren Frowen
