4576
Trum
Beginner
10GBASE-T (RJ45) in Switch WS-C3850-48XS-S
There is a switch WS-C3850-48XS-S. you need to connect the server through a 10Gb sfp transceiver using a twisted pair (RJ 45) category 6 or 7 with this switch. Found only such SNR-SFP + T. Is it possible? Or is there some other SFP transceiver? Give, please the link.
1 ACCEPTED SOLUTION
Seb Rupik
VIP Advisor
Hi there,
Cisco does not produce a 10Gb UTP SPF+ transceiver.
Your cheapest option would probably to use twinax so long as the server is not more that 10 meters away, but would require a SFP+ NIC for your server.
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html
cheers,
Seb.
2 REPLIES 2
Seb Rupik
VIP Advisor
Hi there,
cheers,
Seb.
Thank you
Content for Community-Ad
