4 FC ports between Cisco UCS FI-A and MDS-1 are down
gkhnsmsk7
I am having issues with 4 fibre channel ports on my Cisco UCS and MDS environment.
The connection and configuration on my FI-A is like below:
interface fc2/1
  channel-group 1 force
  no shutdown
interface fc2/2
  no shutdown
interface fc2/3
  channel-group 2 force
  no shutdown
interface fc2/4
  no shutdown
interface san-port-channel 1
channel mode active
switchport mode NP
interface san-port-channel 2
channel mode active
switchport mode NP
sh int fc2/1
fc2/1 is down (Error disabled)
Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
Port WWN is 20:41:00:2a:6a:0b:94:80
Admin port mode is NP, trunk mode is off
snmp link state traps are enabled
Port vsan is 10
Receive data field Size is 2112
Beacon is turned off
Belongs to san-port-channel 1
1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
46 frames input, 4168 bytes
16 discards, 0 errors
0 CRC, 0 unknown class
0 too long, 0 too short
30 frames output, 8880 bytes
0 discards, 0 errors
19 input OLS, 19 LRR, 0 NOS, 0 loop inits
56 output OLS, 6 LRR, 25 NOS, 0 loop inits
last clearing of "show interface" counters never
sh int fc2/2
fc2/2 is down (Error disabled)
Port WWN is 20:42:00:2a:6a:0b:94:80
Port vsan is 10
45 frames input, 3856 bytes
12 discards, 0 errors
33 frames output, 9768 bytes
22 input OLS, 22 LRR, 0 NOS, 0 loop inits
33 output OLS, 0 LRR, 11 NOS, 0 loop inits
sh int san-port-channel 1
san-port-channel 1 is down (No operational members)
Port WWN is 24:01:00:2a:6a:0b:94:80
Port vsan is 10
78 frames input, 6848 bytes
24 discards, 0 errors
54 frames output, 15984 bytes
35 input OLS, 35 LRR, 0 NOS, 0 loop inits
79 output OLS, 5 LRR, 32 NOS, 0 loop inits
Member[1] : fc2/1
Member[2] : fc2/2
sh int san-port-channel 2
san-port-channel 2 is down (No operational members)
Port WWN is 24:02:00:2a:6a:0b:94:80
Port vsan is 10
19 frames input, 1672 bytes
12 frames output, 3232 bytes
6 input OLS, 6 LRR, 0 NOS, 0 loop inits
14 output OLS, 3 LRR, 6 NOS, 0 loop inits
Member[1] : fc2/3
Member[2] : fc2/4
The connection and configuration on my MDS devices is like below:
interface fc1/1
  switchport rate-mode dedicated
  switchport description FI-A port1
  switchport trunk mode off
  port-license acquire
  no shutdown
interface fc1/2
  switchport description FI-A port2
  no shutdown
interface fc1/3
  switchport description FI-A port3
  no shutdown
interface fc1/4
  switchport description FI-A port4
  no shutdown
interface port-channel 1
  channel mode active
interface port-channel 2
  channel mode active
sh int fc1/1
fc1/1 is down (Link failure or not-connected)
    Port description is FI-A port1
    Port WWN is 20:01:54:7f:ee:9b:1d:d8
    Admin port mode is auto, trunk mode is off
    Port vsan is 10
    Belongs to port-channel 1
    5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      61 frames input, 17876 bytes
      87 frames output, 7764 bytes
      5343 input OLS, 13 LRR, 654 NOS, 0 loop inits
      589 output OLS, 32 LRR, 5699 NOS, 562 loop inits
sh int fc1/2
fc1/2 is down (Link failure or not-connected) Port description is FI-A port2 Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN) Port WWN is 20:02:54:7f:ee:9b:1d:d8 Admin port mode is auto, trunk mode is off snmp link state traps are enabled Port vsan is 10 Receive data field Size is 2112 Beacon is turned off Belongs to port-channel 1 5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 55 frames input, 16188 bytes 0 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 74 frames output, 6496 bytes 0 discards, 0 errors 20 input OLS, 2 LRR, 2 NOS, 0 loop inits 36 output OLS, 34 LRR, 18 NOS, 18 loop inits sh int fc1/3 fc1/3 is down (Link failure or not-connected) Port description is FI-A port3 Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN) Port WWN is 20:03:54:7f:ee:9b:1d:d8 Admin port mode is auto, trunk mode is off snmp link state traps are enabled Port vsan is 10 Receive data field Size is 2112 Beacon is turned off Belongs to port-channel 2 5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 22 frames input, 6340 bytes 0 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 30 frames output, 2588 bytes 0 discards, 0 errors 7 input OLS, 0 LRR, 0 NOS, 0 loop inits 14 output OLS, 14 LRR, 7 NOS, 7 loop inits sh int fc1/4 fc1/4 is down (Link failure or not-connected) Port description is FI-A port4 Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN) Port WWN is 20:04:54:7f:ee:9b:1d:d8 Admin port mode is auto, trunk mode is off snmp link state traps are enabled Port vsan is 10 Receive data field Size is 2112 Beacon is turned off Belongs to port-channel 2 5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 25 frames input, 7300 bytes 0 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 33 frames output, 2980 bytes 0 discards, 0 errors 11 input OLS, 3 LRR, 4 NOS, 0 loop inits 15 output OLS, 12 LRR, 9 NOS, 8 loop inits sh int port-channel 1 port-channel 1 is down (No operational members) Hardware is Fibre Channel Port WWN is 24:01:54:7f:ee:9b:1d:d8 Admin port mode is auto, trunk mode is off snmp link state traps are enabled Port vsan is 10 5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 124 frames input, 36104 bytes 0 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 171 frames output, 15220 bytes 0 discards, 0 errors 5367 input OLS, 17 LRR, 658 NOS, 0 loop inits 629 output OLS, 68 LRR, 5719 NOS, 582 loop inits Member[1] : fc1/1 Member[2] : fc1/2
sh int port-channel 2
port-channel 2 is down (No operational members) Hardware is Fibre Channel Port WWN is 24:02:54:7f:ee:9b:1d:d8 Admin port mode is auto, trunk mode is off snmp link state traps are enabled Port vsan is 10 5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 47 frames input, 13640 bytes 0 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 63 frames output, 5568 bytes 0 discards, 0 errors 18 input OLS, 3 LRR, 4 NOS, 0 loop inits 29 output OLS, 26 LRR, 16 NOS, 15 loop inits Member[1] : fc1/3 Member[2] : fc1/4
When I try to disable/enable the ports on both sides I see the following error messages and the ports are automatically errDisabled on FI-A.
MDS-1
MDS-1 %PORT-5-IF_DOWN_OLS_RCVD: %$VSAN 10%$ Interface fc1/1 is down (OLS received) port-channel 1 FI-A port1 MDS-1 %PORT-5-IF_DOWN_OLS_RCVD: %$VSAN 10%$ Interface fc1/2 is down (OLS received) port-channel 1 FI-A port2 MDS-1 %PORT-5-IF_DOWN_OLS_RCVD: %$VSAN 10%$ Interface fc1/3 is down (OLS received) port-channel 2 FI-A port3 MDS-1 %PORT-5-IF_DOWN_OLS_RCVD: %$VSAN 10%$ Interface fc1/4 is down (OLS received) port-channel 2 FI-A port4
FI-A FI-A %PORT-2-IF_DOWN_ERROR_DISABLED: %$VSAN 10%$ Interface fc2/1 is down (Error disabled) FI-A %PORT-2-IF_DOWN_ERROR_DISABLED: %$VSAN 10%$ Interface fc2/2 is down (Error disabled) FI-A %PORT-2-IF_DOWN_ERROR_DISABLED: %$VSAN 10%$ Interface vfc1478 is down (Error disabled) server 5/4, VHBA fc1 FI-A %PORT-2-IF_DOWN_ERROR_DISABLED: %$VSAN 10%$ Interface vfc1466 is down (Error disabled) server 5/5, VHBA fc1 FI-A %PORT-2-IF_DOWN_ERROR_DISABLED: %$VSAN 10%$ Interface vfc1410 is down (Error disabled) server 5/2, VHBA fc1 . . . .
I hope someone can help me out on this issue.
Thanks.
I could the solve the problem by enabling trunk protocol on my MDS switch.
Before
MDS-1# sh trunk protocol
Trunk Protocol is disabled
After
Trunk Protocol is enabled
Many thanks for your help!
Kirk J
What version of MDS and UCSM are you running?  Need to make sure you aren't hitting an OUI issue (https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvk63036/?rfs=iqvred )
Also please do a #show int fc x/y transceiver details, for ports on the FIs and the MDS (don't need all of them unless they are different transceiver model numbers)
Kirk...
neilmart
Definitely looks like the bug Kirk mentioned. If you do not verify the traces of the bug, provide the transceiver details as he mentioned. Check fill pattern on FI and the MDS match. Check the speed on each side. See if you are able to bring up the interfaces without using port-channel.
Best Regards,
Neil Martin     .ılı.ılı.
Technical Consultant Engineer
Unified Computing Systems and Server Virtualization
SUSE Certified Administrator
In Enterprise Linux 12
Vmware Certified Professional
Data Center Virtualization 2019
thanks for your replies. Actually the ports stopped working after a power outage in our "datacenter". We have the same configuration on our FI-B and MDS-2, which are up and running.
Versions:
UCSM: 2.2(8f)
Fabric Interconnect: 5.2(3)N2(2.28f)
MDS: 5.2(8a)
As far as I can see I'm not hitting that bug
MDS-1# show wwn switch
Switch WWN is 20:00:54:7f:ee:9b:1d:d8
MDS-1# sh fcid company-id-from-wwn 20:00:54:7f:ee:9b:1d:d8
Extracted oui: 0x547FEE
Below MDS transceiver outputs. I think I see high Optical Rx Power dbm levels because the port is errDisabled on FI-A.
MDS-1# sh int fc1/1 transceiver
fc1/1 sfp is present
    Name is CISCO-AVAGO
    Manufacturer's part number is SFBR-5780APZ-CS2
    Revision is G2.3
    Serial number is AGD170687JL
    Cisco part number is 10-2418-01
    Cisco pid is DS-SFP-FC8G-SW
    FC Transmitter type is short wave laser w/o OFC (SN)
    FC Transmitter supports short distance link length
    Transmission medium is multimode laser with 62.5 um aperture (M6)
    Supported speeds are - Min speed: 2000 Mb/s, Max speed: 8000 Mb/s
    Nominal bit rate is 8500 Mb/s
    Link length supported for 50/125mm fiber is 50 m
    Link length supported for 62.5/125mm fiber is 20 m
    Cisco extended id is unknown (0x0)
    No tx fault, rx loss, no sync exists, diagnostic monitoring type is 0x68
    SFP Diagnostics Information:
        Temperature           :  33.28 C
        Voltage               :   3.28 V
        Current               :   7.88 mA
        Optical Tx Power      :  -3.53 dBm
        Optical Rx Power      : -25.85 dBm      --
        Tx Fault count  : 0
    Note: ++  high-alarm; +  high-warning; --  low-alarm; -low-warning
MDS-1# sh int fc1/2 transceiver
fc1/2 sfp is present
    Name is CISCO-AVAGO
    Revision is G2.3
    Serial number is AGD170681U6
        Temperature           :  33.72 C
        Voltage               :   3.28 V
        Current               :   6.10 mA
        Optical Tx Power      :  -2.51 dBm
        Optical Rx Power      : -27.96 dBm      --
        Tx Fault count  : 0
MDS-1# sh int fc1/3 transceiver
fc1/3 sfp is present
    Name is CISCO-AVAGO
    Revision is G2.3
    Serial number is AGD170687J3
        Temperature           :  32.77 C
        Voltage               :   3.28 V
        Current               :   5.59 mA
        Optical Tx Power      :  -2.44 dBm
        Optical Rx Power      : -24.20 dBm      --
        Tx Fault count  : 0
MDS-1# sh int fc1/4 transceiver
fc1/4 sfp is present
    Name is CISCO-AVAGO
    Revision is G2.3
    Serial number is AGD170681UN
        Temperature           :  33.98 C
        Voltage               :   3.27 V
        Current               :   6.51 mA
        Optical Rx Power      : -26.58 dBm      --
        Tx Fault count  : 0
FI-A transceiver outputs:
FI-A(nxos)# sh int fc2/1 transceiver
fc2/1 sfp is present
    Name is CISCO-AVAGO
    Revision is G2.3
    Serial number is AGA17078XHN
    Link length supported for 50/125um fiber is 50 m
    Link length supported for 62.5/125um fiber is 20 m
    Link length supported for 50/125um OM3 fiber is 150 m
    No tx fault, no rx loss, in sync state, diagnostic monitoring type is 0x68
    Digital diagnostics feature not supported in SFP
FI-A(nxos)# sh int fc2/2 transceiver
fc2/2 sfp is present
    Name is CISCO-AVAGO
    Revision is G2.3
    Serial number is AGA170383FF
FI-A(nxos)# sh int fc2/3 transceiver
fc2/3 sfp is present
    Name is CISCO-AVAGO
    Revision is G2.3
    Serial number is AGA170383F5
    No tx fault, no rx loss, no sync exists, diagnostic monitoring type is 0x68
FI-A(nxos)# sh int fc2/4 transceiver
fc2/4 sfp is present
    Name is CISCO-AVAGO
    Revision is G2.3
    Serial number is AGA170383GH
I didn't try the ports without port-channel yet, going to give it a try.
Before
After
