09-12-2019 01:48 AM
I am having issues with 4 fibre channel ports on my Cisco UCS and MDS environment.
The connection and configuration on my FI-A is like below:
interface fc2/1 channel-group 1 force no shutdown interface fc2/2 channel-group 1 force no shutdown interface fc2/3 channel-group 2 force no shutdown interface fc2/4 channel-group 2 force no shutdown interface san-port-channel 1 channel mode active switchport mode NP interface san-port-channel 2 channel mode active switchport mode NP sh int fc2/1 fc2/1 is down (Error disabled) Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN) Port WWN is 20:41:00:2a:6a:0b:94:80 Admin port mode is NP, trunk mode is off snmp link state traps are enabled Port vsan is 10 Receive data field Size is 2112 Beacon is turned off Belongs to san-port-channel 1 1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 46 frames input, 4168 bytes 16 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 30 frames output, 8880 bytes 0 discards, 0 errors 19 input OLS, 19 LRR, 0 NOS, 0 loop inits 56 output OLS, 6 LRR, 25 NOS, 0 loop inits last clearing of "show interface" counters never sh int fc2/2 fc2/2 is down (Error disabled) Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN) Port WWN is 20:42:00:2a:6a:0b:94:80 Admin port mode is NP, trunk mode is off snmp link state traps are enabled Port vsan is 10 Receive data field Size is 2112 Beacon is turned off Belongs to san-port-channel 1 1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 45 frames input, 3856 bytes 12 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 33 frames output, 9768 bytes 0 discards, 0 errors 22 input OLS, 22 LRR, 0 NOS, 0 loop inits 33 output OLS, 0 LRR, 11 NOS, 0 loop inits last clearing of "show interface" counters never sh int san-port-channel 1 san-port-channel 1 is down (No operational members) Hardware is Fibre Channel Port WWN is 24:01:00:2a:6a:0b:94:80 Admin port mode is NP, trunk mode is off snmp link state traps are enabled Port vsan is 10 1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 78 frames input, 6848 bytes 24 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 54 frames output, 15984 bytes 0 discards, 0 errors 35 input OLS, 35 LRR, 0 NOS, 0 loop inits 79 output OLS, 5 LRR, 32 NOS, 0 loop inits last clearing of "show interface" counters never Member[1] : fc2/1 Member[2] : fc2/2 sh int san-port-channel 2 san-port-channel 2 is down (No operational members) Hardware is Fibre Channel Port WWN is 24:02:00:2a:6a:0b:94:80 Admin port mode is NP, trunk mode is off snmp link state traps are enabled Port vsan is 10 1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 19 frames input, 1672 bytes 6 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 12 frames output, 3232 bytes 0 discards, 0 errors 6 input OLS, 6 LRR, 0 NOS, 0 loop inits 14 output OLS, 3 LRR, 6 NOS, 0 loop inits last clearing of "show interface" counters never Member[1] : fc2/3 Member[2] : fc2/4
The connection and configuration on my MDS devices is like below:
interface fc1/1 switchport rate-mode dedicated switchport description FI-A port1 switchport trunk mode off port-license acquire channel-group 1 force no shutdown interface fc1/2 switchport rate-mode dedicated switchport description FI-A port2 switchport trunk mode off port-license acquire channel-group 1 force no shutdown interface fc1/3 switchport rate-mode dedicated switchport description FI-A port3 switchport trunk mode off port-license acquire channel-group 2 force no shutdown interface fc1/4 switchport rate-mode dedicated switchport description FI-A port4 switchport trunk mode off port-license acquire channel-group 2 force no shutdown interface port-channel 1 channel mode active switchport rate-mode dedicated switchport trunk mode off interface port-channel 2 channel mode active switchport rate-mode dedicated switchport trunk mode off sh int fc1/1 fc1/1 is down (Link failure or not-connected) Port description is FI-A port1 Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN) Port WWN is 20:01:54:7f:ee:9b:1d:d8 Admin port mode is auto, trunk mode is off snmp link state traps are enabled Port vsan is 10 Receive data field Size is 2112 Beacon is turned off Belongs to port-channel 1 5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 61 frames input, 17876 bytes 0 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 87 frames output, 7764 bytes 0 discards, 0 errors 5343 input OLS, 13 LRR, 654 NOS, 0 loop inits 589 output OLS, 32 LRR, 5699 NOS, 562 loop inits
sh int fc1/2 fc1/2 is down (Link failure or not-connected) Port description is FI-A port2 Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN) Port WWN is 20:02:54:7f:ee:9b:1d:d8 Admin port mode is auto, trunk mode is off snmp link state traps are enabled Port vsan is 10 Receive data field Size is 2112 Beacon is turned off Belongs to port-channel 1 5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 55 frames input, 16188 bytes 0 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 74 frames output, 6496 bytes 0 discards, 0 errors 20 input OLS, 2 LRR, 2 NOS, 0 loop inits 36 output OLS, 34 LRR, 18 NOS, 18 loop inits sh int fc1/3 fc1/3 is down (Link failure or not-connected) Port description is FI-A port3 Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN) Port WWN is 20:03:54:7f:ee:9b:1d:d8 Admin port mode is auto, trunk mode is off snmp link state traps are enabled Port vsan is 10 Receive data field Size is 2112 Beacon is turned off Belongs to port-channel 2 5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 22 frames input, 6340 bytes 0 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 30 frames output, 2588 bytes 0 discards, 0 errors 7 input OLS, 0 LRR, 0 NOS, 0 loop inits 14 output OLS, 14 LRR, 7 NOS, 7 loop inits sh int fc1/4 fc1/4 is down (Link failure or not-connected) Port description is FI-A port4 Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN) Port WWN is 20:04:54:7f:ee:9b:1d:d8 Admin port mode is auto, trunk mode is off snmp link state traps are enabled Port vsan is 10 Receive data field Size is 2112 Beacon is turned off Belongs to port-channel 2 5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 25 frames input, 7300 bytes 0 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 33 frames output, 2980 bytes 0 discards, 0 errors 11 input OLS, 3 LRR, 4 NOS, 0 loop inits 15 output OLS, 12 LRR, 9 NOS, 8 loop inits sh int port-channel 1 port-channel 1 is down (No operational members) Hardware is Fibre Channel Port WWN is 24:01:54:7f:ee:9b:1d:d8 Admin port mode is auto, trunk mode is off snmp link state traps are enabled Port vsan is 10 5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 124 frames input, 36104 bytes 0 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 171 frames output, 15220 bytes 0 discards, 0 errors 5367 input OLS, 17 LRR, 658 NOS, 0 loop inits 629 output OLS, 68 LRR, 5719 NOS, 582 loop inits Member[1] : fc1/1 Member[2] : fc1/2
sh int port-channel 2 port-channel 2 is down (No operational members) Hardware is Fibre Channel Port WWN is 24:02:54:7f:ee:9b:1d:d8 Admin port mode is auto, trunk mode is off snmp link state traps are enabled Port vsan is 10 5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec 47 frames input, 13640 bytes 0 discards, 0 errors 0 CRC, 0 unknown class 0 too long, 0 too short 63 frames output, 5568 bytes 0 discards, 0 errors 18 input OLS, 3 LRR, 4 NOS, 0 loop inits 29 output OLS, 26 LRR, 16 NOS, 15 loop inits Member[1] : fc1/3 Member[2] : fc1/4
When I try to disable/enable the ports on both sides I see the following error messages and the ports are automatically errDisabled on FI-A.
MDS-1
MDS-1 %PORT-5-IF_DOWN_OLS_RCVD: %$VSAN 10%$ Interface fc1/1 is down (OLS received) port-channel 1 FI-A port1 MDS-1 %PORT-5-IF_DOWN_OLS_RCVD: %$VSAN 10%$ Interface fc1/2 is down (OLS received) port-channel 1 FI-A port2 MDS-1 %PORT-5-IF_DOWN_OLS_RCVD: %$VSAN 10%$ Interface fc1/3 is down (OLS received) port-channel 2 FI-A port3 MDS-1 %PORT-5-IF_DOWN_OLS_RCVD: %$VSAN 10%$ Interface fc1/4 is down (OLS received) port-channel 2 FI-A port4
FI-A FI-A %PORT-2-IF_DOWN_ERROR_DISABLED: %$VSAN 10%$ Interface fc2/1 is down (Error disabled) FI-A %PORT-2-IF_DOWN_ERROR_DISABLED: %$VSAN 10%$ Interface fc2/2 is down (Error disabled) FI-A %PORT-2-IF_DOWN_ERROR_DISABLED: %$VSAN 10%$ Interface vfc1478 is down (Error disabled) server 5/4, VHBA fc1 FI-A %PORT-2-IF_DOWN_ERROR_DISABLED: %$VSAN 10%$ Interface vfc1466 is down (Error disabled) server 5/5, VHBA fc1 FI-A %PORT-2-IF_DOWN_ERROR_DISABLED: %$VSAN 10%$ Interface vfc1410 is down (Error disabled) server 5/2, VHBA fc1 . . . .
I hope someone can help me out on this issue.
Thanks.
Solved! Go to Solution.
09-12-2019 06:26 AM
I could the solve the problem by enabling trunk protocol on my MDS switch.
Before
MDS-1# sh trunk protocol Trunk Protocol is disabled
After
MDS-1# sh trunk protocol Trunk Protocol is enabled
Many thanks for your help!
09-12-2019 05:02 AM
What version of MDS and UCSM are you running? Need to make sure you aren't hitting an OUI issue (https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvk63036/?rfs=iqvred )
Also please do a #show int fc x/y transceiver details, for ports on the FIs and the MDS (don't need all of them unless they are different transceiver model numbers)
Kirk...
09-12-2019 05:13 AM
Definitely looks like the bug Kirk mentioned. If you do not verify the traces of the bug, provide the transceiver details as he mentioned. Check fill pattern on FI and the MDS match. Check the speed on each side. See if you are able to bring up the interfaces without using port-channel.
Best Regards,
Neil Martin .ılı.ılı.
Technical Consultant Engineer
Unified Computing Systems and Server Virtualization
SUSE Certified Administrator
In Enterprise Linux 12
Vmware Certified Professional
Data Center Virtualization 2019
09-12-2019 05:57 AM
thanks for your replies. Actually the ports stopped working after a power outage in our "datacenter". We have the same configuration on our FI-B and MDS-2, which are up and running.
Versions:
UCSM: 2.2(8f)
Fabric Interconnect: 5.2(3)N2(2.28f)
MDS: 5.2(8a)
As far as I can see I'm not hitting that bug
MDS-1# show wwn switch Switch WWN is 20:00:54:7f:ee:9b:1d:d8 MDS-1# sh fcid company-id-from-wwn 20:00:54:7f:ee:9b:1d:d8 Extracted oui: 0x547FEE
Below MDS transceiver outputs. I think I see high Optical Rx Power dbm levels because the port is errDisabled on FI-A.
MDS-1# sh int fc1/1 transceiver fc1/1 sfp is present Name is CISCO-AVAGO Manufacturer's part number is SFBR-5780APZ-CS2 Revision is G2.3 Serial number is AGD170687JL Cisco part number is 10-2418-01 Cisco pid is DS-SFP-FC8G-SW FC Transmitter type is short wave laser w/o OFC (SN) FC Transmitter supports short distance link length Transmission medium is multimode laser with 62.5 um aperture (M6) Supported speeds are - Min speed: 2000 Mb/s, Max speed: 8000 Mb/s Nominal bit rate is 8500 Mb/s Link length supported for 50/125mm fiber is 50 m Link length supported for 62.5/125mm fiber is 20 m Cisco extended id is unknown (0x0) No tx fault, rx loss, no sync exists, diagnostic monitoring type is 0x68 SFP Diagnostics Information: Temperature : 33.28 C Voltage : 3.28 V Current : 7.88 mA Optical Tx Power : -3.53 dBm Optical Rx Power : -25.85 dBm -- Tx Fault count : 0 Note: ++ high-alarm; + high-warning; -- low-alarm; -low-warning MDS-1# sh int fc1/2 transceiver fc1/2 sfp is present Name is CISCO-AVAGO Manufacturer's part number is SFBR-5780APZ-CS2 Revision is G2.3 Serial number is AGD170681U6 Cisco part number is 10-2418-01 Cisco pid is DS-SFP-FC8G-SW FC Transmitter type is short wave laser w/o OFC (SN) FC Transmitter supports short distance link length Transmission medium is multimode laser with 62.5 um aperture (M6) Supported speeds are - Min speed: 2000 Mb/s, Max speed: 8000 Mb/s Nominal bit rate is 8500 Mb/s Link length supported for 50/125mm fiber is 50 m Link length supported for 62.5/125mm fiber is 20 m Cisco extended id is unknown (0x0) No tx fault, rx loss, no sync exists, diagnostic monitoring type is 0x68 SFP Diagnostics Information: Temperature : 33.72 C Voltage : 3.28 V Current : 6.10 mA Optical Tx Power : -2.51 dBm Optical Rx Power : -27.96 dBm -- Tx Fault count : 0 Note: ++ high-alarm; + high-warning; -- low-alarm; -low-warning MDS-1# sh int fc1/3 transceiver fc1/3 sfp is present Name is CISCO-AVAGO Manufacturer's part number is SFBR-5780APZ-CS2 Revision is G2.3 Serial number is AGD170687J3 Cisco part number is 10-2418-01 Cisco pid is DS-SFP-FC8G-SW FC Transmitter type is short wave laser w/o OFC (SN) FC Transmitter supports short distance link length Transmission medium is multimode laser with 62.5 um aperture (M6) Supported speeds are - Min speed: 2000 Mb/s, Max speed: 8000 Mb/s Nominal bit rate is 8500 Mb/s Link length supported for 50/125mm fiber is 50 m Link length supported for 62.5/125mm fiber is 20 m Cisco extended id is unknown (0x0) No tx fault, rx loss, no sync exists, diagnostic monitoring type is 0x68 SFP Diagnostics Information: Temperature : 32.77 C Voltage : 3.28 V Current : 5.59 mA Optical Tx Power : -2.44 dBm Optical Rx Power : -24.20 dBm -- Tx Fault count : 0 Note: ++ high-alarm; + high-warning; -- low-alarm; -low-warning MDS-1# sh int fc1/4 transceiver fc1/4 sfp is present Name is CISCO-AVAGO Manufacturer's part number is SFBR-5780APZ-CS2 Revision is G2.3 Serial number is AGD170681UN Cisco part number is 10-2418-01 Cisco pid is DS-SFP-FC8G-SW FC Transmitter type is short wave laser w/o OFC (SN) FC Transmitter supports short distance link length Transmission medium is multimode laser with 62.5 um aperture (M6) Supported speeds are - Min speed: 2000 Mb/s, Max speed: 8000 Mb/s Nominal bit rate is 8500 Mb/s Link length supported for 50/125mm fiber is 50 m Link length supported for 62.5/125mm fiber is 20 m Cisco extended id is unknown (0x0) No tx fault, rx loss, no sync exists, diagnostic monitoring type is 0x68 SFP Diagnostics Information: Temperature : 33.98 C Voltage : 3.27 V Current : 6.51 mA Optical Tx Power : -2.44 dBm Optical Rx Power : -26.58 dBm -- Tx Fault count : 0 Note: ++ high-alarm; + high-warning; -- low-alarm; -low-warning
FI-A transceiver outputs:
FI-A(nxos)# sh int fc2/1 transceiver fc2/1 sfp is present Name is CISCO-AVAGO Manufacturer's part number is SFBR-5780APZ-CS2 Revision is G2.3 Serial number is AGA17078XHN FC Transmitter type is short wave laser w/o OFC (SN) FC Transmitter supports short distance link length Transmission medium is multimode laser with 62.5 um aperture (M6) Supported speeds are - Min speed: 2000 Mb/s, Max speed: 8000 Mb/s Nominal bit rate is 8500 Mb/s Link length supported for 50/125um fiber is 50 m Link length supported for 62.5/125um fiber is 20 m Link length supported for 50/125um OM3 fiber is 150 m Cisco extended id is unknown (0x0) No tx fault, no rx loss, in sync state, diagnostic monitoring type is 0x68 Digital diagnostics feature not supported in SFP FI-A(nxos)# sh int fc2/2 transceiver fc2/2 sfp is present Name is CISCO-AVAGO Manufacturer's part number is SFBR-5780APZ-CS2 Revision is G2.3 Serial number is AGA170383FF FC Transmitter type is short wave laser w/o OFC (SN) FC Transmitter supports short distance link length Transmission medium is multimode laser with 62.5 um aperture (M6) Supported speeds are - Min speed: 2000 Mb/s, Max speed: 8000 Mb/s Nominal bit rate is 8500 Mb/s Link length supported for 50/125um fiber is 50 m Link length supported for 62.5/125um fiber is 20 m Link length supported for 50/125um OM3 fiber is 150 m Cisco extended id is unknown (0x0) No tx fault, no rx loss, in sync state, diagnostic monitoring type is 0x68 Digital diagnostics feature not supported in SFP FI-A(nxos)# sh int fc2/3 transceiver fc2/3 sfp is present Name is CISCO-AVAGO Manufacturer's part number is SFBR-5780APZ-CS2 Revision is G2.3 Serial number is AGA170383F5 FC Transmitter type is short wave laser w/o OFC (SN) FC Transmitter supports short distance link length Transmission medium is multimode laser with 62.5 um aperture (M6) Supported speeds are - Min speed: 2000 Mb/s, Max speed: 8000 Mb/s Nominal bit rate is 8500 Mb/s Link length supported for 50/125um fiber is 50 m Link length supported for 62.5/125um fiber is 20 m Link length supported for 50/125um OM3 fiber is 150 m Cisco extended id is unknown (0x0) No tx fault, no rx loss, no sync exists, diagnostic monitoring type is 0x68 Digital diagnostics feature not supported in SFP FI-A(nxos)# sh int fc2/4 transceiver fc2/4 sfp is present Name is CISCO-AVAGO Manufacturer's part number is SFBR-5780APZ-CS2 Revision is G2.3 Serial number is AGA170383GH FC Transmitter type is short wave laser w/o OFC (SN) FC Transmitter supports short distance link length Transmission medium is multimode laser with 62.5 um aperture (M6) Supported speeds are - Min speed: 2000 Mb/s, Max speed: 8000 Mb/s Nominal bit rate is 8500 Mb/s Link length supported for 50/125um fiber is 50 m Link length supported for 62.5/125um fiber is 20 m Link length supported for 50/125um OM3 fiber is 150 m Cisco extended id is unknown (0x0) No tx fault, no rx loss, in sync state, diagnostic monitoring type is 0x68 Digital diagnostics feature not supported in SFP
I didn't try the ports without port-channel yet, going to give it a try.
09-12-2019 06:26 AM
Before
After
