Beginner
6248 FI firmware upgrade
can i upgrade firmware on my 6248 Fabric interconnects by themselves or do i need to download the UCS firmware bundle ?
current f/w is 5.0 x
2 REPLIES 2
Re: 6248 FI firmware upgrade
You will need to download the UCS Infrastructure "A Bundle" in order to upgrade. You will upgrade UCSM and then both Fabric Interconnects and IOMs.
We havn't made it to 5.0 firmware yet, but if you check your 'show version' output the numbers at the end are the firmware versions.
system image file is: bootflash:///installables/switch/ucs-6100-k9-system.5.0.3.N2.3.23f.bin
Highlighted
Beginner
thanks . got it /.
Content for Community-Ad
August's Community Spotlight Awards
