6248 Supported Fibre SFP's
thehxman101
Is the following Fibre SFP supported on the 6248 FTLF8524P2BNV
The matrix is as follows:
DS-SFP-FC4G-SW
DS-SFP-FC4G-LW
Leo Laohoo
I don't think so because those SFP ID are not Cisco-branded.
abbharga
Level 4
Level 4
The SFPs are supported SFPs.
Here is the URL to the 6248 for the list of all supported SFPs.
http://www.cisco.com/en/US/prod/collateral/ps10265/ps11544/data_sheet_c78-675245.pdf
./Abhinav
Ahmed Ismail
please all i have Cisco UCS 6248UP and i want connect fabric to cisco catalyts 3650 g
the switch show error disable becuz  gbic not compatible with sfp in 3650 g
is there any other compatible gbic with fabric and switch 3650 ?
thanks
The SFP's in the original post are fibre channel SFP's, not Ethernet ones ! if this is your situation, it can't work !
