08-18-2016 07:56 AM - edited 03-01-2019 12:51 PM
There seems to be an issue with CIMC lockups on C-class servers ,it has been mentioned that you can access CIMC from the CLI of the ESXi of the host machine and possibly reset ,is this true does anyone know and if so can the same be done on C-class ?
08-18-2016 08:33 AM
It depends on the firmware version you are running.
If you are able to ping the CIMC, but not able to SSH/HTTP, you could be running into this CIMC memory leak defect
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCun88303/?reffering_site=dumpcr
-Majid
08-18-2016 08:52 AM
yep that's my issue ,problem is getting someone half the world to power it down tied in with an hours downtime ... if there is any other way ???
08-18-2016 09:18 AM
Unfortunately, there is not. You'd have to get someone on site to plug those power cables off and plug them back in.
-Majid
08-19-2016 12:10 AM
I have been told this is possible in B-class servers ,do we know if this is correct ?
