Add another disk for UCS 210
iantra123
Level 3
Level 3
We want to buy UCS 210 from stores, because they give us discount.
We want to buy for example R210-BUN-3.
But we want to know how to buy the hard drives?
Does the UCS have already the caddy for the hard drive? and buy just the hard drive following the UCS Part Number?
or have we to buy the caddy and the hard drive like buying HP Servers Hard Drives?
regards,
Antra
Hey Atra -
The additional harddrives should ship with the drive sleds, so you shouldn't need to order any additional hardware.
Jen
Not applicable
As R210-BUN-3 is Cisco C210 M2, the choices are
  • R2XX-D500GCSATA 500 GB SATA 7.2 K RPM SFF HDD/hot plug/C-Series drive sled
  • A03-D073GC2 73 GB 6 G SAS 15 K RPM SFF HDD/hot plug/drive sled mounted
  • A03-D146GA2 146 GB 6 G SAS 10 K RPM SFF HDD/hot plug/drive sled mounted
  • A03-D146GC2 146GB 6Gb SAS 15K RPM SFF HDD/hot plug/drive sled mounted
  • A03-D300GA2 300 GB 6 G SAS 10 K RPM SFF HDD/hot plug/drive sled mounted
  • A03-D600GA2 600GB 6Gb SAS 10K RPM SFF HDD/hot plug/drive sled mounted
  • A03-D100SSD 100GB SATA SSD SFF HDD/hot plug/drive sled mounted
http://www.cisco.com/en/US/prod/ps10265/ps10493/c-series_part_numbers.html
You cannot buy the caddy/tray/sled without hard drives and third-party hard drives
(like Seagate Constellation.2 SED SAS 1.0 TB) are not supported.
Q. Can my customer purchase their own third-party hard drives and use them in their UCS Server?
A. Installation of components that are outside the control of Cisco in terms of specifications
can have adverse affects on the performance of the equipment either immediately or over a period
such as exceeding draw on PSU (Power Supplies) over time, cooling of components within the chassis
etc. Furthermore, the “sled” that is used to house/mount the disk drives in the UCS-C Series Chassis
is not available as a spare, so mounting of 3rd party drives would present a significant challenge
to somebody who wishes to do this.
The official policy on the use of 3rd party equipment is covered in our Warranty Terms and conditions:
http://www.cisco.com/en/US/prod/unified_computing_systems_warranty.pdf
gsharma4
Hi Antra,
please find the below Compatiable HDD part number for C210:-
A03-D146GC2
146GB 6 Gb SAS 15K RPM SFF
SAS
146 GB
A03-D300GA2
300 GB 6 Gb SAS 10K RPM SFF HDD
SAS
300 GB
UCS-HDD300GI2F105
300GB 6Gb SAS 15K RPM SFF HDD
SAS
300 GB
A03-D500GC3
500 GB 6 Gb SATA 7.2K RPM SFF
SATA
500 GB
A03-D600GA2
600 GB 6 Gb SAS 10K RPM SFF HDD
SAS
600 GB
UCS-HDD900GI2F106
900GB 6Gb SAS 10K RPM SFF HDD
SAS
900 GB
A03-D1TBSATA
1 TB 6 Gb SATA 7.2K RPM SFF HDD
SATA
1 TB
SSDs
UCS-SSD100GI1F104
NEW 100GB SATA SSD SFF (STEC)
SATA
100 GB
If you are happy with the answer,please make it answered,
Gaurav
