03-27-2019 03:41 AM
i have a business edition 6000 C220 M5SX and i need to add a second PSU to it , will inserting the second PSU cause the UCS to restart or cause any sort of live service effect?
Solved! Go to Solution.
03-27-2019 04:26 AM
The power system in the C series is designed to have HA/Failover, and is hot swap.
You can add the additional PSU live.
Make sure you are adding the same voltage source (i.e. 110 for both, or 220 for both).
Kirk...
03-27-2019 04:27 AM
This should not cause any issues as PSU are hot swappable, however, would recommend conducting this during a maintenance window.
03-27-2019 04:26 AM
Kirk...
03-27-2019 04:27 AM
