358
Beginner
adding vNICs to vNIC LAN Connectivity Policy via UCS Central PowerTool (BETA)
When I try to add an vNIC to an VNIC LAN Connectivity policy by using the UCS Central Powertool (v0.94) I getting the following error:
 D:\Scripts> Add-UcsCentralVnic -Name vmnic0 -VnicLanConnPolicy test
Add-UcsCentralVnic : ucc01:Policy org-root/lan-conn-pol-test is resolved from remote policy server. Create/Delete/Modify operations are not allowed.
At line:1 char:1
+ Add-UcsCentralVnic -Name vmnic0 -VnicLanConnPolicy test
    + CategoryInfo          : NotSpecified: (unidentified-fail:String) [Add-UcsCentralVnic], Exception
    + FullyQualifiedErrorId : 170,Cisco.UcsCentral.Cmdlets.AddUcsCentralVnic
whatever I try, I still get the same error every time ("Create/Delete/Modify operations are not allowed").
I'm using UCS Central version 1.2(1a) and UCS Central PowerTool version 0.94 (BETA)
Everyone's tags (1)
1 ACCEPTED SOLUTION
Advocate
Maybe you post your problem
Maybe you post your problem in https://communities.cisco.com/docs/DOC-53127 where other issues related to UCS Center powershell are discussed.
1 REPLY 1
Advocate
Content for Community-Ad
August's Community Spotlight Awards
