Hi folks,
I experienced a UPS failure which dropped one of my C210 M2's. It came back up fine, ESXi fired right up and it's successfully hosting several VM's so everything appears to be technically operational. However, in the CIMC my inventory screen is coming up blank. Nothing shows on the CPU, Memory, or Network Adapters tabs. Power Supplies and Storage appear to display correctly. PCI Adapters gives the following notice: "Error: Operation failed" in a pop-up window.
Is there a way for me to force the CIMC to repopulate my inventory. Is the fact that it's blank an indication of damage?
Thanks in advance for any help anyone can offer.
Joel,
Is the behavior same when you access CIMC web page from different PCs / web browsers ?
SSH into CIMC and try if it reports correctly via CLI
scope chassis
show detail
show cpu detail
show pci-adapter detail
Padma
Hi Padramas,
I get the same behavior through SSH and the command line. I've attached a screenshot of the results (pardon the mistakes - I was dictating commands to a colleague). In addition to this step I've also completely powered down the system, removed the PSU's, reset the CMOS battery, and reflashed the CIMC firmware and BIOS. No change in results so far.
Thanks for your continued time and help.
Joel,
Please open a TAC service request as we need more information.
Steps to collect show tech log bundle
FYI :- If you choose to, you can open SR from this discussion thread
https://supportforums.cisco.com/docs/DOC-13613
Padma
Padramas,
I've opened a TAC service request and attached the CIMC technical support data export. Thank you again for your assistance.
Hi Joel,
Did you get a resolution to this? We are seeing a very similar issue at the moment.
Andries
Hi Andries,
Sorry, I meant to update this but hadn't gotten around to it. Yes it was resolved, but unfortunately it required replacing the chassis. After opening a TAC request a field engineer came out and swapped a new chassis for us.
Best of luck.
