03-21-2019 06:27 AM
I would like to find out the list of VLAN's which are allowed on a particular Port channel using powertool.
Please help me with the powertool command to find the above mentioned details.
03-21-2019 06:32 AM
May be never heard Powertools before ? what is this one ? how it works ?
Do you mean below one :
03-21-2019 06:38 AM - edited 03-21-2019 06:45 AM
I mean Powershell module of Cisco UCS.
03-21-2019 06:45 AM
Then that is Powershell (not Powertools)
here is the example of Powershell start with :
https://www.sherweb.com/blog/fun-with-powershell-plink-cisco-ios-and-powershell/
03-21-2019 07:01 AM
Thanks for your reply.
I am already using UCS Powertool. I just need to know the specific cmdlet to get the list of allowed VLAN's on a port channel.
03-21-2019 06:58 AM
Hello @kunal.bhadra1 ,
Please check if this works for you …
Get-UcsVnicTemplate | Get-UcsVnicInterface
Good way to learn Managed Object Hierarchy is to use following cmdlet.
PS C:\> Get-UcsCmdletMeta -ClassId VnicLanConnTempl -Tree
OrgOrg (UcsOrg) (Get, Add, Set, Remove)
|-VnicLanConnTempl (UcsVnicTemplate) (Get, Add, Set, Remove)
|-FaultInst (UcsFault) (Get)
|-VnicDynamicConPolicyRef (UcsVnicDynamicConPolicyRef) (Get, Add, Remove)
|-VnicEtherIf (UcsVnicInterface) (Get, Add, Set, Remove)
| |-FabricNetflowIPv4Addr (UcsFabricNetflowIPv4Addr) (None)
| |-VnicIPv4If (UcsVnicIPv4If) (Get, Add)
| |-StorageIpV4PooledAddr (UcsStorageIpV4PooledAddr) (None)
| | |-VnicIpV4History (UcsVnicIpV4History) (None)
| |-StorageIpV4StaticAddr (UcsStorageIpV4StaticAddr) (None)
| |-VnicIPv4Dhcp (UcsVnicIPv4Dhcp) (Get, Add, Remove)
| |-VnicIPv4Dns (UcsVnicIPv4Dns) (Get)
| |-VnicIPv4IscsiAddr (UcsVnicIPv4IscsiAddr) (Get, Add, Set, Remove)
| |-VnicIPv4PooledIscsiAddr (UcsVnicIPv4PooledIscsiAddr) (Get, Set)
| |-VnicIPv4StaticRoute (UcsVnicIPv4StaticRoute) (Get)
| |-VnicIpV4MgmtPooledAddr (UcsVnicIpV4MgmtPooledAddr) (Get, Set, Remove)
| |-VnicIpV4PooledAddr (UcsVnicIpV4PooledAddr) (Get)
| |-VnicIpV4ProfDerivedAddr (UcsVnicIpV4ProfDerivedAddr) (Get)
| |-VnicIpV4StaticAddr (UcsVnicIpV4StaticAddr) (Get, Add, Set, Remove)
|-VnicFcOEIf (UcsVnicFcOEIf) (Get)
|-VnicUsnicConPolicyRef (UcsVnicUsnicConPolicyRef) (Get, Add, Remove)
|-VnicVmqConPolicyRef (UcsVnicVmqConPolicyRef) (Get, Add, Remove)
PS C:\>
Original post: https://community.cisco.com/t5/unified-computing-system/powertool-list-vlans-attached-to-vnic-template/td-p/3589927
03-21-2019 07:48 AM - edited 03-21-2019 08:09 AM
Thanks Jaderson,
The above command is get the VLANs' attached to a vnic template. But my requirement is different here.
My requirement is to get the list of VLAN's that are allowed on a Port Channel. I generally get this info by selecting the Fabric A or B on VLAN Manager tab of LAN Uplinks Manager in GUI. I would like to get this information using powertool.
