B200 M3 and Citrix XenServer
mlinder01
Does anybody made experience with the new B200 M3 Blades and XenServer? does this run? also with VIC 1240?
Thanks for inputs
Manuel
8 Replies 8
abbharga
Level 4
Level 4
Hi Manuel,
Let us know if you are facing any issues with your install?
Please make sure to have a look at the h/w and s/w matrix to the driver and the firmware as well as the supported OS requirement.
Do note that the driver for the 1240 will have to be installed as they are not inbox with the OS.
http://www.cisco.com/en/US/docs/unified_computing/ucs/interoperability/matrix/r_hcl_B_rel2.02.pdf
./Abhinav
Hi Abhinav,
Thanks!
So in general B200 M3 and XenServer should work with actual drivers and firmware?
Is there an installation guide for XenServer - VIC 1240 drivers?
Manuel
Yes Manuel,
As long as you isntall the supported OS and corect drivers it should work fine.
There is no such specific gudie from us to install the drivers but the process will remain the same as for installing any other driver on the XenServer.
Thanks!
./Abhinav
mlinder01
Thanks!
Last question, i have to take the .rpm - Redhat drivers for XenServer right?
Manuel
mlinder01
Hi there,
Does anybody know where i find does Cisco UCS drivers for XenServer?
Manuel
Andreas Sartori
I do have a problem with this blade type (mlom 1240), too.
After downloading the driver package, there is just a readme that xenserver 6.0.2 includes the driver already. dmesg shows that fnic and enic modules are loaded and working.
I have configured zoning on the nexus5k, flogi shows my netapp storage and blades logged in. i cant find any luns and my netapp storage just shows "not logged in" when looking at the initiator groups.
when doing a "fcp topology show" i get the following:
Port    Port WWPN                State    Type     Attached WWPN           Port ID
1/29    20:1d:54:7f:ee:9b:a2:c0  Online   F-Port   50:0a:09:82:98:fa:78:c5 0xb30000*
1/30    20:1e:54:7f:ee:9b:a2:c0  Offline  none                                    -
67109   24:c8:54:7f:ee:9b:a2:c0  Online   none     24:c8:54:7f:ee:96:a2:00 0xb30001
                                                   20:00:00:25:b5:11:00:0e 0xb30002
                                                   20:00:00:25:b5:11:00:0c 0xb30004
                                                   20:00:00:25:b5:11:00:0a 0xb30006
so the netapp sees the wwpns of my b200m3 blade.
any ideas how to debug?
solved. i had an error in my zoning configuration.
-andreas
