2123
Highlighted
Beginner
B200M2 Blade server showing Amber LED
I am faceing issue in one of our Cisco UCS B200 M2 blade server, It is showing Amber LED.
We have one chassis with 4 B200 M2 servers all other server are working fine , but the server which is there in the bay 3 is giving Amber LED.
Till now we have work around and did the firmware updated, tested with working service profile, tryied in different bay , changed the CNA card.
But no result , after doing this we are thinging of mother board issue these server is 2 month old and it under warrant. waiting for the solution
Thanks in advance
Sunil
Everyone's tags (2)
1 ACCEPTED SOLUTION
Highlighted
Re: B200M2 Blade server showing Amber LED
Sunil,
The power fluctuation may be due to a faulty mainboard/voltage sensor.  I'd suggest you open up a TAC case and they may decide to replace the blade (mainboard only) for you.
Connect to the UCSM CLI using telnet or SSH, and enable logging with your SSH client to capture the following outputs
(Where X = Chassis #, and Y = Blade #)
UCS-250-A# connect local-mgmt
UCS-A(local-mgmt)# show tech-support chassis X cimc Y
UCS-A(local-mgmt)# exit
UCS-250-A# connect cimc X/Y
[ help ]# sensors power
Attach these outputs to the TAC case when you open it for a quicker resolution.
Robert
4 REPLIES 4
Highlighted
Sunil,
What does UCSM report as the fault with this blade?  There should be an error message in the "Faults" tab for this blade giving you further detail.
Paste it here and we'll be able to guide you further.  Also advise which version of UCSM you're running including the Blade's BIOS & CIMC versions
Robert
Highlighted
Beginner
Robert,
Thanks for reply, attached the SEL logs of the server. And we are running 1.4(3m) version on the chassis and UCSM.
Sunil
Highlighted
Sunil,
Robert
Highlighted
Beginner
Thanks Robert, we have already open the tag case and i have sent the same error screen shot to them.
Waiting for they reply
Sunil
Content for Community-Ad
