BL 480 M5 SQL Server and Numa
phowarth1
I'm running a SQL server on a Cisco BL 480 M5 with 112 Cores assigned and 3tb of memory.  I believe that there are 4 numa nodes in the BL 480 M5.   The VM isn't having trouble from a user perspective.  But I'm seeing high CPU Ready numbers.  It is the only VM on the host as well.  The current cpu assignment is 56 sockets by 2 number of cores per socket.  Ready numbers are averaging 113ms.  With a low of 73ms and a high of 442ms.   Would changing the cpu core to socket allocation improve those numbers?  Also, is there any bios setting that should be set that can improve those numbers?
Thanks.
0 Replies 0
