12-05-2018 07:28 AM
HELLO ALL
i am facing problem installing ESXI ON C240 M5S THE DISKS ARE NOT PRESENT TO INSTALL ON IT HOWEVER TRIED DIFFERENT ESXI IMAGES CUSTOM AND NON CUSTOM with different versions 6.5 u1 6.5 u2 ALL FAILS
please if any one faced it or have the solution
your reply is highly appreciated
12-05-2018 07:38 AM
WHAT IS THE PROBLEM EXACTLY? DO YOU SEE THE RAID CONTROLLER DURING POST? DOES IT CORRECTLY IDENTIFY THE TARGET VIRTUAL DRIVE YOU ARE ATTEMPTING TO BOOT TO?
Can you provide some screen captures of the process? What type of RAID controller did you purchase?
12-05-2018 08:15 AM
the problem exactly is to install esxi image with version 6.2 u1 or 6.2 u2 but the 2 ssd disks local in ucs not present to install esxi on it ( it says none ) (no disks)
yes i can see the raid controller at bios only not in cmic as it is built in raid controller
12-05-2018 11:48 AM - edited 12-05-2018 06:03 PM
ESXi does not support the onboard/embedded controller.
NOTE: Embedded software RAID is limited to Windows and Linux operating systems only. There is no VMWare support for embedded software RAID.
You have to use regular SAS raid controller, or use the drives attached to the local embedded controller in individual AHCI mode for Vmware products.
Kirk...
