ā05-21-2013 09:47 AM - edited ā03-01-2019 11:02 AM
Iam unable to locate installation / setup guide for fresh installation of C260 M2 for PCCE.
Someone do direct me with appropriate links . Also more info on CUCM licensing for setting up on C260 M2
Thanks in advance
ā06-05-2013 12:05 AM
Hello Manjunath,
Please refer the below link
http://www.cisco.com/en/US/docs/unified_computing/ucs/c/hw/C260/install/C260.pdf
ā06-05-2013 06:05 AM
Thanks Anurag!
I had looked into C260 installation Doc earlier.
However i have captured few steps to the best of my knowledge w.r.t dealing with install/config, enclosing the same here for all new beeies ref .
I wish you could advice me more on complete Licensing process involved for C 260 M2 w.r.t pre & post of CCE ( including PCCE on c260).
Thanks in advance
Guide to setup UCS C260 M2:
Create virtual machine with OVA template , download OVA template from cisco sit .
Golden Template
For installing the CUCM , CUIC , Finesse use VOS ( Voice operating system)
Steps to convert VM to Golden Template
1 . Refer
Configure the PCCE Data Server
Before beginning the installation of data server, verify below parameters.
Microsoft SQL 2008 R2
Procedure to Configure PCCE Call Server
Prior installing the Call server , verify below steps.
