07-12-2011 11:22 AM - edited 03-01-2019 09:59 AM
I saw in C-Series that it has an onboard two 1Gigabyte built in, also an expansion slot can be added with two 10Gigabyte to it,... Aside from the fact that they are different in capacity (one is 1G, other is 10G), how they are different from each other? I mean can i just use the built in two 1Gigabyte on the C200 and use that for exsi virtualization and fiber channel connection or do i need the two 10Gigabyte expansion for exsi virtualization an fiber channel connection?
07-12-2011 11:41 AM
The LOM on the C-Series is 1 Gigabyte Ethernet.
http://www.cisco.com/en/US/docs/unified_computing/ucs/interoperability/matrix/r_hcl_C200_rel1.32.pdf
It is using the Intel 82576 Gigabit Ethernet Onboard Controller
If you are doing Fiber Channel you are going to need one of the HBA supporting PCI cards outlined in the above document that is compatabile with ESXi.
07-12-2011 08:18 PM
I see, so the LOM on the C200 M2 is just a basic Intel 82576 which doesn't support vNIC and vHBA.
- So that means that only basic functionality is available on the Intel 82576? No VN-LINK?
- Also is the 1Gigabyte link on the LOM enough to support the C200 M2 when many VMs is installed in the ESXi host?
