04-22-2011 09:50 AM - edited 03-01-2019 09:53 AM
I have chosen to use a single power supply in a c200-m1 server.
Is there a way to disable the alert in CIMC and amber light fault on front LED if this is its normal operating condition?
04-22-2011 10:32 AM
Mike,
To my knowledge there is no way to do this. I am sure in later firmware levels 1 power supply might be seen as normal. As of now, its not. For me 2 power supplies is a rule and adds little cost to the server. Its a cheap price for redundancy.
My 2 cents
David
04-22-2011 01:02 PM
What CIMC code are you running? I'm pretty sure that in most recent versions of code that if you have a single power supply it won't complain and the LED lights should be green on the front.
I'm running CIMC and BIOS version 1.3.1c on a C200M1 with 1 power supply and everything is green for me.
louis
