C200-M2 Qlogic HBA keeps re-sync
I have the following setup
-NetApp Storage
-2 x UCS C200-M2
-Qlogic HBA 4Gbps dual port "QLE2462"
-2 x mds 9124 running 5.0(1a)
The NetApp is stable and and apparently no problems, but one port of each HBA area constantly loosing connectivity, I'm also receiving several OLS and NOS messages
SOERAD-FC-9124-01# sh int fc1/5
fc1/5 is up
    Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
    Port WWN is 20:05:00:05:73:e2:da:00
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
    Port mode is F, FCID is 0x100200
    Port vsan is 10
    Speed is 4 Gbps
    Rate mode is dedicated
    Transmit B2B Credit is 3
    Receive B2B Credit is 16
    Receive data field Size is 2112
    Beacon is turned off
    5 minutes input rate 448 bits/sec, 56 bytes/sec, 0 frames/sec
    5 minutes output rate 600 bits/sec, 75 bytes/sec, 1 frames/sec
      2437809 frames input, 3617093236 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      4237464 frames output, 6791197472 bytes
        3 discards, 0 errors
      1022 input OLS, 442 LRR, 108 NOS, 0 loop inits
      562 output OLS, 608 LRR, 939 NOS, 0 loop inits
      16 receive B2B credit remaining
      3 transmit B2B credit remaining
      3 low priority transmit B2B credit remaining
    Interface last changed at Wed Jun 27 04:06:58 2012
And this keep's increasing....
I have replaced the Patch and nothing, could this be a firmware problem ?  I have looked also at bug navigator and nothing close to this....
Should I consider a FW upgrade ? currently I'm running c200.1.3.2.0
Kind regards,
Bruno Fernandes
Everyone's tags (3)
1 REPLY 1
Highlighted
Just to confirm you've changed all cables and transceivers in the path?
Robert
Content for Community-Ad
Software Conformance Survey
