C220 M3 FCOE and Netapp Fc via nk5
yoedboker
i installed esx 5.5 on a c220 M3 with VIC1225 connected via FCOE to 2 X nk5.
i nstalled netapp FAS2240-4 with FC connectivity to the same nk5.
after set the FCOE feature and configure the FC interface and did the vfc procedure in every switch i can see all the WWPN.
VSAN for now is the same in both switch but i will change it to be different.
i created only 1 zone between esx and netapp and i cant see that netapp recieved a FC login request from server.
my concern is that the VIC caard is not configured correctly or there is a FCOE issue.
does anyone with a VIC1225 experiance this kind of behavior in the implementation?
padramas
Hello Yoed,
If I understood it correctly, you have installed ESXi on storage local to the server but trying to access to data luns ( datastores ) from your SAN array. Is that correct ?
If yes, please provide following information
From CIMC, adapter information
1)   NIV enabled or disabled ?
2)  FIP enabled or disabled ?
3)  Default VLAN configuration ?
From N5K,
show run int eth x/y
show run int vfc X
show vlan fcoe
show int vfc x/y
Is this straight through configuration or links from VIC connects to both N5K in vPC mode ?
Padma
thanks padramas,
you are correct - esxi installed on local disk (sd card).
my problem is to connect the luns.
1)   NIV enabled or disabled ? did not see were to configure (do i need to enable?).
2)  FIP enabled or disabled ? enabled
3)  Default VLAN configuration ? in the VIC i changed to the VSAN VLAN but that didnt help.
regarding the last question each port from VIC connect to each nk5 and i can configure a vpc but i dont know if i need because i dont want to use san portchannel.
Can you please provide interface configuration of N5K switch ports that are connected to VIC adapter ?
NIV ( VNTAG )  information is available in CIMC > Inventory > Cisco VIC adapters > General > Modify Adapter properties > enable VNTAG mode.
Padma
issue solved
it was a QOS parrameters that missconfigured.
thanks for quick responed.
