Community Helping Community
121
Beginner
C220 M3 firmware upgrade path
I have using CIMC firmware version 1.4(7a) and bios ver c220M3.1.7b.0
facing issue DDR3_P1_B1_ECC error and its showed failed memory 4096.
how to troubleshoot this issue?
Please suggest which firmware version needs to upgrade?
1 ACCEPTED SOLUTION
Re: C220 M3 firmware upgrade path
You can just replace the DIMM if it showing failed. You can also try to reseat or swap the DIMM with another slot.
A firmware upgrade will likely not fix that issue.
6 REPLIES 6
Beginner
Initially it was unable to reach CIMC controller. after replacing the RAM slots only working and able to reach my CIMC and application.
The functionally ok, but its shows mentioned the error. DDR3_P1_B1_ECC.
DIMM_B1 failed.
The CIMC functionality will generally work even if there is an overall processor or DIMM failure, provided the CIMC has already been configured prior to those failures..
If you replaced a DIMM, and were previously having issues reaching your CIMC, then you were likely hitting a  memleak issue in the CIMC, which a hard power cycle will resolve, and something you likely did during the DIMM replacement.
You will want to upgrade your CIMC to avoid the memleak issue where the web interface no longer responds.
Kirk...
Hall of Fame Community Legend
A good step-by-step guide on how to upgrade the CIMC firmware can be found HERE.
Beginner
Thanks a lott..
I have swapped the RAM as it is same earlier. working fine. but i am getting error.
DIMM_A1 failed error.
how to fix this error on CIMC?
Highlighted
Beginner
Thanks kirk,
installed firmware version 1.4.7(a) & BIOS version C220M3.1.4.7b.o
PID : SNS-3415-K9
which version i have to upgrade from current version? & upgrade steps.
Content for Community-Ad
FusionCharts will render here
