C240 cant Flogi into Nexus 5548s
akhan0002
Hi All,
I have 3 C240 servers connected to a Nexus 5548. I want to configure FCoE across to them and i have configured the exact same configuration on 6 ports:
vlan 10
  fcoe vsan 10
vsan database
  vsan 10
device-alias mode enhanced
device-alias database
  device-alias name XenServer1_fc0 pwwn 20:00:c0:67:af:2d:d0:07
  device-alias name XenServer1_fc1 pwwn 20:00:c0:67:af:2d:d0:08
  device-alias name XenServer2_fc0 pwwn 20:00:b0:fa:eb:36:11:6f
  device-alias name XenServer2_fc1 pwwn 20:00:b0:fa:eb:36:11:70
  device-alias name XenServer3_fc0 pwwn 20:00:b0:fa:eb:36:11:1b
  device-alias name XenServer3_fc1 pwwn 20:00:b0:fa:eb:36:11:1c
interface vfc1
  bind interface Ethernet1/1
  switchport trunk allowed vsan 10
  no shutdown
interface vfc2
  bind interface Ethernet1/2
  no shutdown
interface vfc3
  bind interface Ethernet1/3
  no shutdown
interface vfc4
  bind interface Ethernet1/4
  no shutdown
interface vfc5
  bind interface Ethernet1/5
  no shutdown
interface vfc6
  bind interface Ethernet1/6
  no shutdown
vsan database
  vsan 10 interface vfc1
  vsan 10 interface vfc2
  vsan 10 interface vfc3
  vsan 10 interface vfc4
  vsan 10 interface vfc5
  vsan 10 interface vfc6
  description ***Link To XenServer1 FCx***
  switchport mode trunk
  switchport trunk allowed vlan 1,10
  spanning-tree port type edge trunk
  description ***Link To XenServer2 FCx***
  description ***Link To XenServer3 FCx***
However Only 1 of the C240s can Flogi into the Nexus switch:
N5K01# show flogi database
INTERFACE        VSAN    FCID           PORT NAME               NODE NAME
vfc5             10    0x150000  20:00:c0:67:af:2d:d0:07 10:00:c0:67:af:2d:d0:07
                           [XenServer1_fc0]
vfc6             10    0x150040  20:00:c0:67:af:2d:d0:08 10:00:c0:67:af:2d:d0:08
                           [XenServer1_fc1]
Total number of flogi = 2.
The other C240s are not logging in and are stuck in initiazing state.
N5K01# show interface vfc1
vfc1 is trunking
    Bound interface is Ethernet1/1
    Hardware is Ethernet
    Port WWN is 20:00:54:7f:ee:3c:b4:ff
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
    Port mode is TF
    Port vsan is 10
    Trunk vsans (admin allowed and active) (10)
    Trunk vsans (up)                       ()
    Trunk vsans (isolated)                 ()
    Trunk vsans (initializing)             (10)
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      19 frames input, 1788 bytes
        0 discards, 0 errors
      20 frames output, 2568 bytes
    last clearing of "show interface" counters Thu Aug 14 12:40:43 2014
    Interface last changed at Fri Aug 15 08:15:53 2014
What could be the possible issue??
akhan0002
Its ok guys, found the issue.
On the C240s, under the 'inventory' then 'properties' than 'Cisco VIC adaptors' than 'vHBAs' you have to have boot enabled for it to flogi into the Nexus.
