Beginner
C240 m3 memory failures
Hope someone can help
c240 m3 256gb of memory is failing memory noise and memorybutterfly test, I am  not sure how to determine which dimms are the culprit
Out put :
MemroyButterfly  test
15 uncorrectable errors
DDR3_P1_A2_ECC: Unknown error code 60500
Uncorrectable Errs from Sel log 15
Memory Noise test:
Same output as above
Thank you in advance
Will
1 ACCEPTED SOLUTION
Re: C240 m3 memory failures
Greetings.
Based on your output, the DIMM in slot A2 is experiencing the Uncorrectable errors.
Kirk...
1 REPLY 1
Greetings.
Kirk...
Content for Community-Ad
August's Community Spotlight Awards
