02-25-2019 04:23 AM - edited 03-01-2019 01:38 PM
Hello all, i think is a simple question but never seen before.
I remove the spare disk from a raid 5 + spare one and in CIMC console i see 3 alerts, one about phisical disk 1 is degraded, other about virtual drive 0 (raid one) is degraded and the phisical disk 16 missing alert.
If disk 16 is the spare one i think alert on disk 1 is some kind of error or is the normal alert operation?
Thanks to all
02-25-2019 04:49 AM
Did all the alerts occur at the same time?
You mention "I remove a spare disk from RAID 5 and spare one" So you removed 2 disks?
Disk 1 might be an actual error. Can you provide screen captures?
02-25-2019 05:02 AM
Sorry, i mean that i remove the spare disk (phisical disk 16), and at the same time i get the alert about phisical disk 1 is degraded.
When i insert disk 16 missing alert goes out and change for degraded, several minutes after disk 1 degraded alert is clear.
Some time later disk 16 degraded alert is cleared and with this virtual drive 0 degraded alert is cleared too.
Sorry cant do screen captures.
Could be disk 1 is the spare and i mistake about that?
02-25-2019 05:04 AM
Yeah, it will be hard to tell what is going on if you are not able to provide screen captures or log outputs of your RAID/disk config.
02-25-2019 05:11 AM
I connect to the ucs and see that disk 1 is dedicated hot spare, so is my mistake and alert is normal behavior.
Thanks a lot
