C460-M4-UCS Managed Management Network
K P SIM
Hi Experts:
I have a UCS managed C460-M4 and I would like to REDUCE SPOF for my Management Network [KVM Console] which is currently limited to Slot 4 with my Cisco VIC.Firmware is 2.2(5b).
Q1. How to achieve it if VIC in Slot 4 has hardware issues (both ports is busted/downed) if I am using Direct Connect (direct to UCS FI-1 port to FI-A and the other to FI-B)?
Q2. I am using IPMI too and since IPMI is configured to use the Management Network on Slot 4 and once Slot 4 is DOWN, my IPMI will stop working too?
Can I use other network ports for IPMI like the MLOB - x 1 Dual-1G Ports and x 1 Dual-10G Ports?
Can I use these above for my Management Network too rather than using the 10G VIC in Slot 4? If I do this, I WILL HAVE to move the VIC in slot 4 to other slot, AM I right? Will this VOID the Direct Connect framework and supportability or WILL IT work or not?
Please help to shed some lights.
SiM
Clifford Aldan
SiM,
There are several methods to integrating UCS C-series with UCS Manager
  • SingleConnect (Sideband)
  • Dual-wire Management (Shared LOM)
  • Direct Connect Mode
These are all covered in the configuration guide: Cisco UCS C-Series Server Integration with Cisco UCS Manager
For your goal (reduce SPOF), Dual-wire Management is the option to use as the other two choices use a single VIC and single wire connection to each FEX/FI
