12-18-2014 08:28 AM - edited 03-01-2019 11:57 AM
Is it possible to change the already deployed system name on a paired cluster of 6248up fi's? Firmware is 2.2 3b...
Solved! Go to Solution.
12-19-2014 07:24 AM
You can also go to to Admin tab> Communication Management (in the filter/drop down) > Management Interfaces > " Virtual IP" field and then change the "Domain Name" which is the third line from bottom to top
-Kenny
12-19-2014 04:28 AM
According to the config guide, this is possible.
F241-POD-1-UCS-1-A# scope system
F241-POD-1-UCS-1-A /system # set
F241-POD-1-UCS-1-A /system # set name niles
Warning: System name modification changes FC zone name and redeploys them non-disruptively
F241-POD-1-UCS-1-A /system* # commit-buffer
niles-A /system #
niles-A /system # set name F241-POD-1-UCS-1
niles-A /system* # commit-buffer
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/cli/config/guide/2-2/b_UCSM_CLI_Configuration_Guide_2_2/b_UCSM_CLI_Configuration_Guide_2_2_chapter_0101.html#task_4F5115C9511C4870A30B890BF0EEFC78
HTH,
/niles
12-19-2014 07:24 AM
-Kenny
07-13-2022 01:03 PM
If you're relying on the self-signed certificate you may need to regenerate it after changing the system hostname:
scope security
scope keyring default
set regen yes
(commit)
