CIMC-Express not working on SRE 910 and 3945
nunnsby_2
Hi there, I can;t get the CIMC-Express component of the SRE to work. I have the followed the document here to the tee:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/cimce/1.0/configuration/guide/CIMCe.html
I have the SRE working and VMs installed and running on the Blade. I have the CIMC-E software installed and running on the Embedded Service Engine and can log into the webpage. So, the Second Core is UP and the Kernel is UP.
The webpage gives an error of: "CIMC-E is not configured."
This corresponds to the actual confirmation command on the CIMC of:
se-192-168-1-14 /router # show hardware
Could not communicate with the router.
Please ensure WSMA is configured correctly by
running the following commands:
  scope cimce
    set username <username>
    set password <password>
    set url <url>
To see your current configuration, run:
  scope cimce
    show config
The router has wsma set up and the username is the same on both the router and the CIMCE. The above commands have been configured, yet it still is not working.
Any ideas? Is this a bug?
0 Replies 0
