CIMC Launch KVM Console
elarkin01
I am on the CIMC and when I select Launch KVM Console,  I get a pop up a Do you want to continue ? I select Continue
It goes to starting application, Verifying application. ( takes about a minute )   then pops up a  Do you want to run this application ?
I check accept the risk and run this application.
It automatically goes to Connecting to KVM Server , then Message popup Login Failed or Timed out. Please try again.
I have set up a admin account under admin.
any suggestions would be greatly appreciated
Edith
27 Replies 27
Thanks Damon,
That fix worked for me.
That's crazy. But hey, worked for me as well. I wonder how it's supposed to work.
Worked for me too. (Windows Server 2003 R2 + Java 7 update 67, hitting the same issue)
worked for me too on OSX.  It was working fine for three days and then changed somehow.  edited the file and good to go.  THANKS DAMON!!!!!
Example Please. Could you highlight your changes with a different color or bold them?
What did you change the user name and password to?
This saved my butt, thank you!!!
Thanks Damon, that was really helpful
Zaira Vega
What is your server firmware version?
Older versions require Java 6
mike.kellys1
Thanks Damon, that worked for me and made me look like a hero to other people on my team who couldn't get it to work.!!!
hshahdil
Debug Logs:
Java Web Start 11.181.2.13 amd64 Using JRE version 1.8.0_181-b13 Java HotSpot(TM) 64-Bit Server VM User home directory = C:\Users\hshahdil ---------------------------------------------------- c: clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message m: print memory usage o: trigger logging p: reload proxy configuration q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack 0-5: set trace level to ---------------------------------------------------- Missing Application-Name manifest attribute for: https://10.59.227.43:443/software/avctNuova.jar.pack.gz KVM/VM Client Version: 5.04.04 (Build 392) scalingmenuchecked from pref storage = true CMDUtil setscalingon = true Scaling state:true scalingMenuChecked::true defScaleMenuValue::true replace numpad replace numpad ** Max Size: W = 3360 H = 2020 ** Window Pref Size: W = 1050 H = 861 ** Max Size: W = 3360 H = 2020 ** Window Pref Size: W = 1050 H = 861 JNLPClassLoader: Finding library VMAPI_DLL.dll JNLPClassLoader: Finding library jawt.dll JNLPClassLoader: Finding library avctKVMIO.dll ProtocolAPCP.receieveSessionSetup : v1.2 APCP = true APCP Version = 260 Supported protocols: [SSLv2Hello, SSLv3, TLSv1, TLSv1.1, TLSv1.2] Enabled protocols: [TLSv1, TLSv1.1, TLSv1.2] Supported ciphers: [TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384, TLS_RSA_WITH_AES_256_CBC_SHA256, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384, TLS_DHE_RSA_WITH_AES_256_CBC_SHA256, TLS_DHE_DSS_WITH_AES_256_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA, TLS_RSA_WITH_AES_256_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA, TLS_DHE_RSA_WITH_AES_256_CBC_SHA, TLS_DHE_DSS_WITH_AES_256_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256, TLS_RSA_WITH_AES_128_CBC_SHA256, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_DSS_WITH_AES_128_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA, TLS_RSA_WITH_AES_128_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_DSS_WITH_AES_128_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, TLS_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_DSS_WITH_AES_256_GCM_SHA384, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_DSS_WITH_AES_128_GCM_SHA256, TLS_EMPTY_RENEGOTIATION_INFO_SCSV, TLS_DH_anon_WITH_AES_256_GCM_SHA384, TLS_DH_anon_WITH_AES_128_GCM_SHA256, TLS_DH_anon_WITH_AES_256_CBC_SHA256, TLS_ECDH_anon_WITH_AES_256_CBC_SHA, TLS_DH_anon_WITH_AES_256_CBC_SHA, TLS_DH_anon_WITH_AES_128_CBC_SHA256, TLS_ECDH_anon_WITH_AES_128_CBC_SHA, TLS_DH_anon_WITH_AES_128_CBC_SHA, SSL_RSA_WITH_DES_CBC_SHA, SSL_DHE_RSA_WITH_DES_CBC_SHA, SSL_DHE_DSS_WITH_DES_CBC_SHA, SSL_DH_anon_WITH_DES_CBC_SHA, TLS_RSA_WITH_NULL_SHA256, TLS_ECDHE_ECDSA_WITH_NULL_SHA, TLS_ECDHE_RSA_WITH_NULL_SHA, SSL_RSA_WITH_NULL_SHA, TLS_ECDH_ECDSA_WITH_NULL_SHA, TLS_ECDH_RSA_WITH_NULL_SHA, TLS_ECDH_anon_WITH_NULL_SHA, SSL_RSA_WITH_NULL_MD5, TLS_KRB5_WITH_DES_CBC_SHA, TLS_KRB5_WITH_DES_CBC_MD5] Enabled ciphers: [TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384, TLS_RSA_WITH_AES_256_CBC_SHA256, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384, TLS_DHE_RSA_WITH_AES_256_CBC_SHA256, TLS_DHE_DSS_WITH_AES_256_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA, TLS_RSA_WITH_AES_256_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA, TLS_DHE_RSA_WITH_AES_256_CBC_SHA, TLS_DHE_DSS_WITH_AES_256_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256, TLS_RSA_WITH_AES_128_CBC_SHA256, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_DSS_WITH_AES_128_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA, TLS_RSA_WITH_AES_128_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_DSS_WITH_AES_128_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, TLS_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_DSS_WITH_AES_256_GCM_SHA384, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_DSS_WITH_AES_128_GCM_SHA256] SSL session using protocol TLSv1.2, cipher suite TLS_RSA_WITH_AES_128_CBC_SHA KVMIOWindowListener::setup KVMIOWindowListener::setup m_preemptionSharing::0 CMDUtil setscalingon = true CMDUtil setscalingon = true
In my particular situation I was getting this error: kvm unable to launch the application Server returned HTTP response code: 403 for URL /software/avctNuova.jar.pack.gz
My solution was to edit the viewer.jnlp file in Notepad++. For unknown reasons this file contained an incorrect IP address. I did a replace all operation to change the IP to match my CIMC's IP. Then re-launched and Java prompted me for the usual security warnings and successfully opened the KVM.
Windows 10
Java 8 Update 221
CIMC 4.0(2f) on a Cisco S3260M4
SriramVS62525
In case the suggested solution did not work for you. Please try the following steps which helped me resolve my issue.
KVM Console is not Working
  • Make a note of the service profile template the service profile is attached to.
  • Unbind the service profile template from service profile. Now you will notice the Change Management IP address option will get highlighted.
  • Click Change the Management IP address and choose static instead of esx-mgmt. Enter an unused ip address from the esx-mgmt pool. [Better to choose an ip address on the far range.] Eg:
    10.x.x.233
    255.x.x.x
    10.x.x.1.
    Click OK & close the Window.
  • Now when you launch KVM console, you will notice 2 options namely
    open KVM console with the given static IP or
    with derived IP address from the pool.
    you will be able to open KVM console with either of them.
  • Click Change the Management IP address once again & this time choose esx-mgmt instead of static and Click OK. Close the Window.
  • Check if KVM console is working again.
  • Bind the service profile back to the same service profile template & close.
Thanks ! !
Sriram V S
