CIMC - wrong password
Jean Lofrano
Hi guys!!
I have a UCS C220 working properly, but would like to access in CIMC interface and I don´t have the corret user and password. What is the best way to reset that?
regards,
Chris Deren
This doc shows the procedure:
http://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-c200-m1-high-density-rack-mount-server/111455-setup-cimc-c-series.html
F8 to configure/view CIMC IP
While in BIOS you can press F8 for the CIMC IP address configuration and password reset.
Chris
12 Replies 12
You will need to hook a monitor and keyboard to the server to reset the CIMC password.
Reboot the server and you should see a message on the screen to press "f8" to enter the CIMC setup. From there you can reset the CIMC password.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Thanks guys,
I wouldn´t like to reboot the server...
If I perform the procedure below?  What do you think about?
Procedure
 Command or ActionPurpose
Step 1Server# scope cimcEnters the CIMC command mode.
Step 2Server /cimc # factory-defaultAfter a prompt to confirm, the CIMC resets to factory defaults.
This is not going to work as you will need to enter the credentials to get to this mode. F8 is the only way if you need to reset password.
Chris
Chris Deren
Chris
that prompts for the old password in my situation. is there any way around this?
Having the same problem.  Has anyone figured out how to get past this?  After hitting "F8", you're greeted by a
CURRENT PASSWORD:
NEW PASSWORD:
CONFIRM PASSWORD:
Try "password" or "Cisco1234"
Awesome, I'll try that and provide an update on the results.  Thanks!
password worked.
Were you ever able to reset your CIMC password without knowing the current password? From what I'm reading, you need to update the CIMC BIOS using a DIP switch setting on the motherboard.
AsadShareef6969
If vmware is running, Verify ucs_ipmitool is present you can create new user with admin privileges.
[root@esxi01:~] ls /opt/ucs_tool_esxi/
host-cfg.yaml ucs_host_inventory.py
host-inv-details.yaml ucs_ipmitool <<<<<<<<<<<<<<<<<<<<<<<<<< Verify ipmi tool is present in Cisco UCS server.
host-inv.yaml ucs_tool_inv_read_last_config.yaml
ucs_host_config.py util.py
[root@esxi01:~] /opt/ucs_tool_esxi/ucs_ipmitool user list 1 <<<< to see how many users
ID Name Callin Link Auth IPMI Msg Channel Priv Limit
1 admin true true true ADMINISTRATOR
2 true true true USER
3 true true true USER
[root@esxi01:~] /opt/ucs_tool_esxi/ucs_ipmitool user set name 2 admin1
2 carousel true true true USER <<<<<<<<<<<<<<<<<<<<<<<created new user
[root@esxi01:~] /opt/ucs_tool_esxi/ucs_ipmitool user set password 2 ADgif321!
[root@esxi01:~] /opt/ucs_tool_esxi/ucs_ipmitool user enable 2 <<<<<<<<enabled the user
[root@esxi01:~] /opt/ucs_tool_esxi/ucs_ipmitool channel setaccess 1 2 callin=on ipmi=on link=on privilege=4 <<<<<< giving admin privileges
2 carousel true true true ADMINISTRATOR
[root@esxi01:~]
