Field Notice 70545
441
Scott4891
Beginner
CISCO C220 M5 Hypervisor Installation?
Hey All,
I just need to confirm that the Cisco C220 M5SX blades have embedded LSI controller, which hypervisor hides the drives from the ESXi installer? ESXi 5.5.0 (yes i know, environment limited)
I have configured the drives in RAID 1, as a bootable and still doesn't find the drives. Tried in Legacy and UFEI mode and still unable to find. When I have tired to do some research I came across that it is recommended that you use one of the PCI or Mezzanine base controllers?
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C220/install/C220/raid.html#wp1028426
I am failing to understand if its driver or firmware or actual controller? It just doesn't make any sense.. I don't have any experience with CISCO products...
I guess I am asking where do I go from here?
Thanks in advance.
2 REPLIES 2
Kirk J
Greetings.
If you are referring to the embedded 'software raid/MegaRaid_SR', then no, ESXi does not support it, and you won't be able to make it work.  You can leave the drives in jbod/AHCI mode, and then esxi will see the individual drives, albeit in a non-redundant config.
I would also suspect you would have issues with CPU support when trying to use the newer CPUs with the old OS.
Kirk...
Thanks Kirk,
Yeah, i have set it up as jbod/AHCI and ESXi still doesn't see the individual drives!
Everything i have seen, a minimum of 6.5 for these blades.
As I suspected thank you!
Scott
Create
Recognize Your Peers
Content for Community-Ad
