CIsco CICM 4.x post install issue
Dean Brandt
Hi guys, I have a UCS C220M4 and it was running CICM 2.1 and CICM was accessible and functioning. I upgraded to 4.1 and I get the login page but any attempted login does not work, it just sits there, for days with a cog spinning endlessly. Have tried all the usual suspects in terms of browser. I am semi confident it does not use flash but have tried allowing flash, and turning flash off, any java cache also deleted but sure it doesn't use java either. Can semi ssh to it now and again but that is not a confident process either.
What am I potentially missing here?
Dean Brandt
SOLVED: Simply enter CIMC config (F8) from the boot prompt and set all CIMC settings back to default. When it reboots you will be asked to change password and the default is "password" and the CIMC will seek an IP via DHCP
