Greg Wilkinson
The Cisco IMC Emulator allows users to familiarize themselves with Cisco’s UCS Standalone Management platform, also known as the Cisco Integrated Management Controller (Cisco IMC). It provides access to all three management interfaces Cisco offers today – WebUI, CLI, and the XMLAPI. The Cisco IMC Emulator is supported on the following servers: C220M4, C240M4, C460M4.
The emulator enables users to do the following:
  • View and explore the available Cisco IMC features without the need for physical HW. For example, experiencing the new HTML5 based WebUI that launched with Cisco IMC 3.0(1c) firmware.
  • Become familiar with select Cisco UCS hardware and standalone management solutions before purchasing equipment.
  • Set up automation scripts / programmatic deployments using the XML API. This can save time for our customers.
Current Release 3.0(3f):
The latest release of the Cisco IMC Platform Emulator brings the following changes:
- Emulator is now bundled as an OVA for seamless deployment, eliminating the requirements for pre-configured Linux hosts
- Emulator now has multi-threaded QEMU support, allowing for faster interaction via the API, and overall performance increase
- ZIP file includes individual platform versions if deploying a VM is not possible. These can be run inside RHRL 7.0/CentOS 6.5 and have the same prerequisites as the initial release.
**User Guide for current release is posted in the Attachments section below. The OVA/ZIP files can be found on Box:
Cisco IMC Emulator Downloads - Box
________________________________________________________________________
Previous Releases
Release 3.0(3a)
Cisco IMC Platform Emulator – version 3.0(3a). This release adds many new features, including the following:
- VIC Configuration
- BIOS Configuration
- WebUI based Emulator configuration (previously, this was CLI only)
- Configurable IMC Emulator MAC Address and Serial Number
- Various bug fixes
The Cisco IMC Platform Emulator is now bundled into a single .zip file. The package needs to be unpacked as before, and uses a “launch.sh” script in the root directory (cimc_emulator-3.0.3a) to launch the emulator. Individual platforms can still be accessed using the CLI by navigating to cimc_emulator-3.0.3a\prod\<desired platform>. Please reference the latest user guide for additional details.
You can access the Cisco IMC Emulator platform images from the link below:
Cisco IMC Emulator - Box
The user guide can be found as part of the .zip file and is also posted below.
Initial Release 3.0(1c):
The emulator runs from a 64bit linux host, and was tested with RHEL 7.0 and CentOS 6.5.  When using Windows, you must ensure Virtual Box software is installed, and an appropriate 64 bit linux OS is provided. The host machine must have the tunctl and brctl commands to create the tap network and the bridge network, respectively (these are used for accessing/communicating with the emulated IMC). There is also a configuration file that can be modified in real time, and allows users to adjust various IMC sensor values, mimic faults, and perform device state changes.
The video below provides an overview of the Cisco IMC Emulator and also explains how to install the utility.
Video Link : 16038
This next video outlines general use cases for the IMC Emulator, while also stepping through some examples.
Video Link : 16039
Greg Wilkinson
Apologies for that. Link is working now.
e34999
Beginner
Beginner
Thanks! It works well.
Yasu.Hiro
Beginner
Beginner
I could not access the box link for CIMC Emulator.
Greg Wilkinson
Please try again.
Yasu.Hiro
Beginner
Beginner
Thank you. I downloaded it.
srpisupa
Seems link is broken, can you please check ?
Greg Wilkinson
Please give this another try.
claudia.chen
Beginner
Beginner
Hi Gregory,
Is there a new version of emulator for C220 M5 server? or we can just used the 3.0.3f for M5 servers too?
Thanks and Regards,
Claudia
Andrew Edwards
Enthusiast
Enthusiast
Greg, Is there a public domain link (e.g. not Cisco Drop Box where file age out)? I have looked around (software.cisco.com and cisco.com and developer.cisco.com) and all blog posts and even the community site point back to this page. I cannot seem to find the download link anywhere but here and they are expired.... bummer! If you can post one that would be awesome! Thanks Andy
takayas
Greg Wilkinson
Please try again.
dafonsecaj
Beginner
Beginner
Could you also share the content with me as I too do not have access to the Box link.
Thank-you
Jorge Fonseca
Greg Wilkinson
Yes, links are working.
UCSPA8869
Beginner
Beginner
Is this applicable to the M5 server too? Or is this a different emulator for M5?
Greg Wilkinson
The IMC Emulator is not a currently maintained project. The latest versions are those posted – nothing today for M5.
Thanks!
