Cisco MDS port channel with USC FI
praveenk098
Can anyone help me to configure/troubleshoot Cisco MDS 9148 with Cisco USC ? M stuck in port channel..i have configured but interfaces are not coming UP.It is showing init state.
My Topology is like,
Nexus 5000-->USC FI (single FI) -->Cisco MDS 9148
                                                 --> Two Chassis
Any help would be highly appreciated...
Thanx
Hi Praveen,
It looks like you are hitting the following bug CSCty04686
Add MAC OUI "002a6a", "8c604f", "00defb" for 5k/UCS-FI
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCty04686
To fix this issue you will have to upgrade your MDS switch to the 5.28 release.   The root cause of this issue is that the OUI id 002a6a is not present in the file system for the current version of software that your MDS is running.
6 Replies 6
padramas
Hello Praveen,
Please provide basic necessary info to help you out.
Is trunking enabled on FI ?
Does MDS 9148 supports f-port-channel ? If yes, have you enabled f-port-channel-trunk feature on it ?
Software version on MDS ?
Have you correctly configured  the VSANs ?
Please share " show run int " output from both FI and MDS devices.
Padma
Hello Padramas,
Following are the commands configured on MDS:-
interface fc1/15
  switchport rate-mode dedicated
  port-license acquire
  channel-group 2 force
  no shutdown
interface fc1/16
  no shutdown
fport-channel-trunk is enabled
kickstart image file is: bootflash:/m9100-s3ek9-kickstart-mz.5.0.1a.bin
  kickstart compile time:  12/25/2020 12:00:00 [02/21/2010 20:09:44]
  system image file is:    bootflash:/m9100-s3ek9-mz.5.0.1a.bin
  system compile time:     2/2/2010 17:00:00 [02/21/2010 23:13:41]
Following are the snap shot from UCS manager :-
Manuel Velasco
Hi Praveen,
Have you tried bringing the individual interfaces up on the MDS and UCS?
Can you provide the mac adress of one of the interfaces on the fabric interconnect?
you can get this by runnin the following commands:
F_A# connect nxos
F_A(nxos)# show interface ethernet 1/1 | in Hardware
What software version is your MDS switch running?
Hi Manuel,
Yes MDS and UCS interfaces are UP.
when is run
F_A(nxos)# show interface ethernet 1/1 | in Hardware this command nothing comes.
TMC-UCSFI-A-A(nxos)# sh interface ethernet 1/1 mac-address
Interface                  Mac-Address     Burn-in Mac-Address
Ethernet1/1                002a.6a27.be01  002a.6a27.bdc8
MDS is running :-
Thanx
TMC-UCSFI-A-A(nxos)# sh interface brief
Interface  Vsan   Admin  Admin   Status          SFP    Oper  Oper   Port
                  Mode   Trunk                          Mode  Speed  Channel
                         Mode                                 (Gbps)
fc1/31     1      NP     off     errDisabled      swl    --           --
fc1/32     1      NP     off     errDisabled      swl    --           --
Ethernet      VLAN   Type Mode   Status  Reason                   Speed     Port
Interface        Ch #
Eth1/1        1      eth  fabric up      none                        10G(D) --
Eth1/2        1      eth  fabric up      none                        10G(D) --
Eth1/3        1      eth  fabric up      none                        10G(D) --
Eth1/4        1      eth  fabric up      none                        10G(D) --
Eth1/5        1      eth  access down    SFP not inserted            10G(D) --
Eth1/6        1      eth  access down    SFP not inserted            10G(D) --
Eth1/7        1      eth  access down    SFP not inserted            10G(D) --
Eth1/8        1      eth  access down    SFP not inserted            10G(D) --
Eth1/9        1      eth  access down    SFP not inserted            10G(D) --
Eth1/10       1      eth  access down    SFP not inserted            10G(D) --
Eth1/11       1      eth  access down    SFP not inserted            10G(D) --
Eth1/12       1      eth  access down    SFP not inserted            10G(D) --
Eth1/13       1      eth  access down    SFP not inserted            10G(D) --
Eth1/14       1      eth  access down    SFP not inserted            10G(D) --
Eth1/15       1      eth  trunk  up      none                        10G(D) 100
Eth1/16       1      eth  trunk  up      none                        10G(D) 100
Eth1/17       1      eth  fabric up      none                        10G(D) --
Eth1/18       1      eth  fabric up      none                        10G(D) --
Eth1/19       1      eth  fabric up      none                        10G(D) --
Eth1/20       1      eth  fabric up      none                        10G(D) --
Eth1/21       1      eth  access down    SFP not inserted            10G(D) --
Eth1/22       1      eth  access down    SFP not inserted            10G(D) --
Eth1/23       1      eth  access down    SFP not inserted            10G(D) --
Eth1/24       1      eth  access down    SFP not inserted            10G(D) --
Eth1/25       1      eth  access down    SFP not inserted            10G(D) --
Eth1/26       1      eth  access down    SFP not inserted            10G(D) --
Eth1/27       1      eth  access down    SFP not inserted            10G(D) --
Eth1/28       1      eth  access down    SFP not inserted            10G(D) --
Eth1/29       1      eth  access down    SFP not inserted            10G(D) --
Eth1/30       1      eth  access down    SFP not inserted            10G(D) --
output ommitted
Here it shows that Fc1/31- 32 which are in trunk , status is errdisabled and admin trunk mode is off
Hi Praveen,
