06-06-2012 03:50 AM - edited 03-01-2019 10:27 AM
We need help .We have UCS setup it has about 4 chassis and 19 blade.I need to get CPU ,memory utilization of each blade.How can we get it.
Also I need to get network bandwidth of each blade .
Please help me.
Victor
06-06-2012 07:10 AM
Victor,
UCSM cannot provide information about CPU and memory utilization of a blade. However, I am not sure whether SNMP MIBs supported by UCSM can provide utilization counters. OS running on these blades can provide such information.
Regarding network bandwidth, you can monitor the utilization of end points at different places
The VIC ( NIc ) stats are available under service profile.
Server and Uplink port stats are under Equipment > FI
Mezz ports on the backplane are found under Equipment > Chassis > IOM > Backplane
For continuous monitoring, you would need use other monitoring solutions like MRTG, Solarwinds etc.
If you have configured threshold policies, UCSM can generate alerts if the utilization exceeds configured threshold value.
Padma
01-14-2015 08:21 PM
Hi Padma,
I know this is a stale thread but wanted to confirm if the MIBs now support the ability to gather utilization data natively from the B series blades or C series rack mount servers? Or is it still they case that we need to derive this data from the hypervisor?
Thank you!
Amir
