04-02-2020 08:44 AM
We are trying to configure Zabbix for Alerting and monitoring of Cisco UCS.
can you guide me on how to do this.?
UCS Central 2.0(1i)
Zabbix version 3.4.
Thank you.
04-02-2020 09:38 AM
If you are looking for help with Zabbix specifically, you should check out their forum. For UCS configuration, you would just be modifying SNMP configuration per Zabbix instruction.
https://www.zabbix.com/forum/zabbix-help/383240-zabbix-monitoring-cisco-ucs
08-25-2020 03:01 AM
Hello @Wes Austin and @SrikanthV
I have become a Zabbix convert recently and I was trying to add CIMC to Zabbix via IPMI. I know IPMI is working because I can get output from the ipmitool. But Zabbix ain't playing ball. Anyone had any luck with UCS and Zabbix using IPMI instead of SNMP?
root@ZABBIX-01:/home/admin# ipmitool -U zabbix -H 192.168.2.108 -I lanplus -L user -y C53740EFBD7BF20522D1C5DA6529AC851CD5CA47 -A OEM session info all session handle : 32 slot count : 4 active sessions : 2 user id : 5 privilege level : USER session type : IPMIv2/RMCP+ channel number : 0x01 console ip : 0.0.0.0 console mac : 1c:55:40:c0:70:3d console port : 53305
