Cisco UCS iSCSI boot question
joeharb
Level 5
Level 5
I am having trouble with getting this to work.  I don't control the iSCSI side of the equation so I am just trying to make sure everything is correct on the UCS side.  When we boot we get an the "Initialize error 1"
If I attach to FI via ssh I am able to ping the target ip's.  The SAN administrator says that the UCS has to register before itself (which isn't occuring) prior to him giving it space.  Everything I have seen the LUN's and Mask are created prior to boot...is this required?
Joe
6 Replies 6
Get to the boot policy, you will see at the bottom of the screen, saying set iscsi boot parameters, set the iscsi pool and initiator and target, you will be all set.
Follow this link to configure correctly:
http://wwtvirtualization.files.wordpress.com/2011/12/flexpod-iscsi-boot-fixed.pdf
thank you,
AK G
Hello Joe,
A few questions
UCSM version ?
Does any other blades work ?
What storage array is being used here ?
SSH into FI , connect to the adapter and please provide  the following output
connect adapter x/y/z
connect
attach-mcp
iscsi_get_config
Padma
UCSM version
2.0(2r)
We have another blade the other chasis that has ESX installed on the local drive and is using the iSCSI SAN as it datastore, therefore I know I connectivity to the SAN.  The storage array is a emc CX4-120.
adapter 2/1/1 (mcp):1# iscsi_get_config
vnic iSCSI Configuration:
vnic_id: 5
          link_state: Up
       Initiator Cfg:
     initiator_state: ISCSI_INITIATOR_READY
initiator_error_code: ISCSI_BOOT_NIC_NO_ERROR
                vlan: 0
         dhcp status: false
                 IQN: iqn.1992-04.com.cisco:2500
             IP Addr: 192.168.0.109
         Subnet Mask: 255.255.255.0
             Gateway: 192.168.0.2
          Target Cfg:
          Target Idx: 0
               State: INVALID
          Prev State: ISCSI_TARGET_GET_SESSION_INFO
        Target Error: ISCSI_TARGET_LOGIN_ERROR
                 IQN: iqn.1992-04.com.emc:cx.apm00101701431:a2
             IP Addr: 192.168.0.2
                Port: 3260
            Boot Lun: 0
          Ping Stats: Success (19.297ms)
          Target Idx: 1
               State: INVALID
                 IQN: iqn.1992-04.com.emc:cx.apm00101701431:b2
             IP Addr: 192.168.0.3
                Port: 3260
            Boot Lun: 0
          Ping Stats: Success (18.229ms)
adapter 2/1/1 (mcp):2#
Update I have changed the iqn for the target and now I getting different output, but still inialize error 1.
nic_id: 6
          link_state: Up
       Initiator Cfg:
                vlan: 0
         dhcp status: false
          Target Cfg:
          Target Idx: 0
               State: ISCSI_TARGET_LUN_INITIALIZE
          Prev State: ISCSI_TARGET_DISABLED
        Target Error: ISCSI_TARGET_LUN_INIT_ERROR
                 IQN: iqn.1992-04.com.emc:cx.apm00101701431.a2
                Port: 3260
            Boot Lun: 0
          Ping Stats: Success (18.543ms)
          Target Idx: 1
                 IQN: iqn.1992-04.com.emc:cx.apm00101701431.b2
                Port: 3260
            Boot Lun: 0
          Ping Stats: Success (18.489ms)
Try giving the LUN an ID of 1.
Also I see:
                vlan: 0
Do you have the vNIC in a VLAN?
Have a nice doc and video on my side of the great stuggle iSCSI was to get working.
http://realworlducs.com/cisco-ucs-iscsi-boot-appliance-ports/
Craig
My UCS Blog http://realworlducs.com
Craig,
I used your docs and video for most of my setup (Good Stuff).  The SAN administrator has said that he needs my initiators to be registered before he can mask them, is this true or does the actual SAN stuff need to be completed prior to boot?  I have checked vnic and it has vlan 2000 set to native.  I have also found other instance where the
iscsi_get_config shows a vlan value of 0, on your setup did it show the actual vlan?  After I made some changes to the target I did get different results as stated above:
                vlan: 0
         dhcp status: false
          Target Cfg:
          Target Idx: 0
Is this better as in have I attached to the SAN but just don't have any luns avaialble?
Joe
