jasonsha
Level 5
Level 5
Cisco UCS Platform Emulator, Release 3.0(2cPE1)
CONFIGURATION IMPORT NOTE:  Importing configuration backups (All, System, or Logical) taken from the UCS Platform Emulator (UCSPE) to physical UCS Manager domains is not recommended or supported by Cisco TAC.  UCSPE backups should only be imported to UCSPE domains.
The UCS Platform Emulator version 3.0(2cPE1) is a platform release that ONLY supports the 6324 Fabric Interconnect based domains.  No other Fabric Interconnect (6100 / 6200) will work with this UCSPE.
New Hardware Features
Cisco UCS Platform Emulator, Release 3.0(2cPE1), adds support for the following new hardware:
  • Cisco UCS B420 M3 Blade Server (UCSB-B420-M3)
  • Cisco UCS B22 M3 Blade Server (UCSB-B22-M3)
  • Cisco UCS B200 M4 Blade Server (UCSB-B200-M4)
  • Cisco UCS C220 M4 Rack Server (UCSC-C220-M4S/L)
  • Cisco UCS C240 M4 Rack Server (UCSC-C240-M4S/L/S2/X)
  • Cisco Blade Server Adapter VIC 1340 (UCSB-MLOM-40G-03)
  • Cisco Blade Server Adapter VIC 1380 (UCSB-VIC-M83-8P)
  • Cisco Rack Server Adapter VIC 1227 (UCSC-MLOM-CSC-02)
  • Changes in the UCS Platform Emulator VM Console
          – Modifications to the VM Console login
          – Modifications to the VM Console Options Menu
          – Modifications to the Network Settings
          – Modifications to the System Settings
          – More details added to the Status Summary display
Known Limitations
Cisco UCS Platform Emulator, Release 3.0(2cPE1) has the following limitations:
  • In the UCSM component topology, the link between the rack server and fabric interconnect is shown as down.
  • Firmware version of components in UCSPE is not visible on the Cisco UCS Central.
  • Disconnecting of the servers by unconfiguring their server ports does not impact the server state.
  • We recommended that you check the imported configuration on the Control Panel to ensure there are no missing components or unsupported components. Unsupported or missing components can impact discovery and it is out of the limitation of the UCSPE catalog that such a scenario can occur.  We suggest you delete the unsupported components and add the component manually on the Control Panel. Occasionally, import of rack servers might fail.
  • Live import of the configuration is possible only with the UCS Mini and not with other versions of the Cisco UCS Manager.
NOTE: From UCS PE 2.2(1bPE1) onwards, UCS PE supports uploading the B-Series and C-Series server firmware bundles.  Because of the large file sizes of the firmware bundles, UCS PE only supports uploading of only the stripped-down versions (attached to this document), which includes only the firmware metadata but not the actual firmware itself in the binaries.  The stripped-down version of the firwmare bundles which contain metadata only of the B-series and C-series server firmware is reduced to approximately 50 kB in size.
richard.kessay
Level 5
Level 5
Awesome Job - Love the New HTML5 interface!
bjmoore01
Community Member
Boots up in ESXi with a failed mount:  UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY
downloaded twice (OVA) and tried it thick and thin provisioned still getting the same. - have to run this as root and I cannot find a root pw.
bjmoore01
Community Member
I downloaded the ZIP and ran VMware Converter and received the same message - But found the issue
I am running this on a lab ESX server and the time server cannot be reached on this VLAN. The time was off by several years and gave an error on mount telling me of this.
milestone1300
Hi Billye, I am facing the same issue with you now.
can I ask how you solve the issue?
thanks in advance.
milestone1300
I think I have figured what to do. Just to add the NTP to the ESXi. seems like to solve my issue. Thanks anyway.
bjmoore01
Community Member
I updated the time on the host and everything worked.
Salem Neaz
Cannot download this file. Download stops after 50 ~60 MB. Any suggestion.
ericwill
Reach out directly to me at ericwill at Cisco dot com.
milestone1300
i was downloading from my corporate network, and had the same issue. Try to download from other internet connection if that is the case.
smartydeep
Community Member
Hi Team,
I am unable to open the kvm console for a blade. Is this functionality not possible thru the emulator ?
deepak
ttsao
Community Member
In 2.x release notes:
Keyboard/Video/Mouse (KVM)— KVM is a cut-through interface. Cisco UCS Platform Emulator
does not support KVM because there are no physical servers attached to the emulation system to
which KVM could connect. Launching the KVM console does not display an error message.
brwashin
Thanks.
Atif Raees
i have tried to download the file but every time download gets reset at 100 or 120 MB.
can anybody help on this
brwashin
Retry it. Mine stopped at 200megs. I waited 5 minutes and let it run overnight.
Jackong
have the same issue cannot continue downloading.....
