03-09-2013 05:24 PM - edited 03-01-2019 10:55 AM
Does UCS (Servers and Storage) have to have Nexus infrastructure or it can also work with Cisco Catalyst 6509 series switches.
If I understand correctly, Nexus is recommended switches for optimal performance and UCS should also work with Cisco Catalyst infrastructure as well.
Solved! Go to Solution.
03-09-2013 07:00 PM
Both switches will work fine. If you already have Catalyst, then you can use that for IP connectivity with UCS.
Nexus platform offering higher speeds and more connectivity options reducing number of devices you have in the rack.
03-09-2013 07:00 PM
