03-11-2013 08:24 AM
A new UCSM patch release is available for download on cisco.com: patch release 2.1(1b). Links to download this release are as follows:
Release notes are available at:
http://www.cisco.com/en/US/docs/unified_computing/ucs/release/notes/UCS_28313.html
Release 2.1(1b) adds support for the following:
The following caveats are resolved in the 2.1(1b) release:
Bug ID | Description |
CSCud56660 | Duplicate license IDs will no longer cause LicenseAG process to core. |
CSCud10237 | The eight default port licenses for flexible GEM on the FI will be available for use. |
CSCud60746 | When Call Home is enabled, the fabric interconnect no longer reboots with the following reset reason: Service: callhome server hap reset |
CSCue38650 | The UCSM PSU policy and IOMs are no longer out of sync after the IOMs are rebooted. |
CSCud70368 | UCS Central is now correctly creating the crossdomain.xml file on UCSM member domains. |
CSCud40412 | When regenerating a new keyring or certificate, the new certificate is now successfully published to the FI webserver and can be obtained by the http process. |
CSCud53700 | The portAG process no longer crashes while activating the Fabric Interconnect NX-OS software during upgrade. |
CSCud59230 | Port channels no longer go down after upgrading to UCSM 2.1. |
CSCub22238 | The Cisco UCS 6100 Series Fabric Interconnects no longer contain a vulnerability in the Netconf interface. |
CSCud20253 | Power capping on the Cisco UCS B420 blade server can now support 32GB DIMMS. |
CSCue46817 | After upgrading to Release 2.1(1b) or higher, a Cisco UCS B440 M1/M2 blade using a RAID key attached to a LSI MegaRAID SAS 9260 will no longer generate a "Missing RAID Key" fault alert. |
CSCud27494 | Traffic to a blade server will no longer be dropped and forwarded to another working link when an uplink is shutdown either on the fabric interconnect or from the upstream switch. |
CSCud54919 | On blade servers that are not associated with a service profile, CIMC could not respond from UCS Manager at the same time. |
CSCuc38555 | Legacy USB support items can no longer be changed in the BIOS setup. |
CSCud19629 | FCoE Uplink interface faults are now visible in the Cisco UCS Manager GUI. |
CSCud20765 | When defined through a service profile template, SRIOV virtual functions (VFs) are no longer populated incorrectly in the instantiated service profiles. |
CSCuc44209 | Cisco UCS Manager no longer displays the names for PSUs connected to a Cisco Nexus 2200 Series FEX in reverse order. |
03-26-2013 09:37 AM
A newer version is available - see this post -> https://communities.cisco.com/message/117438#117438
