11-29-2014 10:35 AM - edited 03-01-2019 11:56 AM
Hello Community,
I'm practising with the Cisco UCS Manager Emulator, however I'm having a problem resolving the servers, see image. Can someone let me know where I'm going wrong?
Carlton
cpatte7372
11-29-2014 02:30 PM
I dont use the emulator that much but for what I understand, you need to select your hardware.. did you select the blade you want to use?
That "Needs resolution" usually shows up in the real UCSM when you decomission a blade and you have not removed it.
-Kenny
04-03-2015 09:05 AM
Right click on the blade picture, click on resolve slot issue, there will be a link, click on the link to accept the blade, then you can re-ack the blade
04-03-2015 09:44 AM
Also, you will not be able to re-ack the blade until identifying step is complete. You can watch the progress in FSM. When it reach 100%, the re-ack link will be available for you.
