04-08-2013 05:08 AM - edited 03-01-2019 10:58 AM
Need help here to configure the FCoE Uplink + Ethernet Uplink in Port channel
Following is the connectivity details from 6248, 5548 and VNX5500.
I have configured Port Channel in following way on Both Fabric Interconnect
After Configuring above things I am getting following Faults on Servers
For NetApp3240 ENM source pinning failed, I have allowed VLAN ID 21 in Uplink manager then too this Link state is not showing UP and Same thing go for both FC_vHBA
Kinldy help me to configure the setup
-Amit
04-08-2013 05:34 AM
Hello Amit,
For Ethernet vNIC with ENM source pinning failed,please check whether configured on that vNIC is allowed on respective FI Ethernet uplinks
For vHBAs, please make sure that VSAN to VLAN mapping is configured correctly on FI and N5K.
connect nxos a
show int vfc 768
show int port-channel
Padma
04-08-2013 07:06 AM
Thanks fory quick revert Padma,
Below is the out for all commands which you asked
Switch-A(nxos)# show interface vfc 768
vfc768 is down (NPV upstream port not available)
Bound interface is Vethernet8960
Port description is server 1/1, VHBA FC_vHBA_1
Hardware is Virtual Fibre Channel
Port WWN is 22:ff:00:2a:6a:09:8c:3f
Admin port mode is F, trunk mode is on
snmp link state traps are enabled
Port vsan is 100
1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
414 frames input, 50796 bytes
1 discards, 0 errors
12478 frames output, 24145448 bytes
0 discards, 0 errors
last clearing of "show interface" counters never
Interface last changed at Mon Apr 8 09:35:05 2013
tulip-A(nxos)# show interface port-channel 4
port-channel4 is up
Hardware: Port-Channel, address: 547f.eee2.5b76 (bia 547f.eee2.5b76)
Description: C: FcoeUplink
MTU 1500 bytes, BW 20000000 Kbit, DLY 10 usec,
Encapsulation ARPA
Port mode is trunk
full-duplex, 10 Gb/s
Beacon is turned off
Input flow-control is off, output flow-control is off
Switchport monitor is off
EtherType is 0x8100
Members in this channel: Eth2/7, Eth2/8
30 seconds input rate 1400 bits/sec, 175 bytes/sec, 0 packets/sec
30 seconds output rate 280 bits/sec, 35 bytes/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 672 bps, 0 pps; output rate 352 bps, 0 pps
RX
43 unicast packets 234 multicast packets 0 broadcast packets
277 input packets 135320 bytes
43 jumbo packets 0 storm suppression bytes
0 giants 0 input error 0 short frame 0 overrun 0 underrun 0 watchdog 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 unicast packets 244 multicast packets 0 broadcast packets
244 output packets 39698 bytes
0 jumbo packets
0 output errors 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble
0 Tx pause
1 interface resets
tulip-A(nxos)# show interface port-channel 5
port-channel5 is up
Hardware: Port-Channel, address: 547f.eee2.5b7b (bia 547f.eee2.5b7b)
Encapsulation ARPA
Port mode is trunk
EtherType is 0x8100
Members in this channel: Eth2/12, Eth2/13
30 seconds input rate 192 bits/sec, 24 bytes/sec, 0 packets/sec
30 seconds output rate 192 bits/sec, 24 bytes/sec, 0 packets/sec
input rate 384 bps, 0 pps; output rate 368 bps, 0 pps
RX
0 unicast packets 238 multicast packets 0 broadcast packets
238 input packets 42180 bytes
0 jumbo packets 0 storm suppression bytes
0 Rx pause
TX
0 unicast packets 243 multicast packets 0 broadcast packets
243 output packets 40252 bytes
0 jumbo packets
0 Tx pause
1 interface resets
Do let me know anything else is required from my end
Regarding ENM source pinning issue it got resolved after chaning Port channel setting at N5K end. We made it port channel mode active at N5K end and it got started working. Also wanted to check if we enable "vpc" at N5K end do we need to do any changes at 6248 lelve?
Awaiting for your quick revert
-Amit
04-08-2013 07:21 AM
Amit,
Have you configured any hard pinning for vHBA 768 ( server 1/1 ) ?
Is VSAN 100 / FCoE vlan mapping created on N5K switch ?
Can you disable / enable the FCoE port channel interface ( if it is not in production ) ?
Regarding ethernet port-channel, no additional configuration is needed on FI. If FI is in End host mode, you can configure N5K vpc interface as STP trunk edge.
Padma
04-08-2013 07:36 AM
No, we haven't configured any hard pinning
Issue got resolved after changing "vsan" & "vfc" setting at N5K end.
Yes, we are running FIs in End Host mode but while configuring "vpc" at N5K end getting following error / issue
id Port Status Consistency Reason Active vlans
2 Po2 up failed vpc port channel -
mis-config due to vpc
links in the 2 switches
connected to different
partners
Let me know what details you want from N5k, will provide you at earliest
Update: Regarding Major Faults in Admin tag
How can I clear this errors ?
-Amit
04-09-2013 04:33 AM
Any updated on above questions ?
I am still facing both issues as describe above
1. vPC - error message
2. Major faults on UCSM
Please help
-Amit
04-09-2013 10:24 PM
Hello Amit,
1) UCSM fault - F1083 - VSAN membership down
This is cosmetic error message as we create vfc as a trunk interface but is initialized only certain VSANs.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCud81857
2) vPC status
Please share the output of following commands from both N5K switches
show vpc
show run int port-channel
sh int port-channel
Padma
04-10-2013 01:09 AM
Below is the ouput for two commands "show run int port-channel
primary# sh run int po2 membership
!Command: show running-config interface port-channel2 membership
!Time: Wed Feb 25 07:55:31 2009
version 5.2(1)N1(1b)
description ***Link to FI-A in R17***
switchport mode trunk
switchport trunk allowed vlan 12-13,21,101-600
spanning-tree port type edge
spanning-tree bpdufilter enable
interface Ethernet1/3
channel-group 2 mode active
interface Ethernet1/4
interface Ethernet1/5
description ***Link to FI-B in R18***
primary# sh run int po3 membership
!Command: show running-config interface port-channel3 membership
!Time: Wed Feb 25 07:57:14 2009
interface Ethernet1/8
channel-group 3 mode active
interface Ethernet1/9
interface Ethernet1/10
primary# sh int po2
port-channel2 is up
Hardware: Port-Channel, address: 002a.6a0a.4caa (bia 002a.6a0a.4caa)
Description: ***Link to FI-A in R17***
MTU 1500 bytes, BW 30000000 Kbit, DLY 10 usec
Encapsulation ARPA
Port mode is trunk
EtherType is 0x8100
Members in this channel: Eth1/3, Eth1/4, Eth1/5
30 seconds input rate 504 bits/sec, 0 packets/sec
30 seconds output rate 2256 bits/sec, 0 packets/sec
input rate 456 bps, 0 pps; output rate 656 bps, 0 pps
RX
22208045 unicast packets 747374 multicast packets 27634234 broadcast packets
50589653 input packets 49083144072 bytes
21411174 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 Rx pause
TX
2801196 unicast packets 353162904 multicast packets 549464 broadcast packets
356513564 output packets 25978572978 bytes
101325 jumbo packets
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
35 interface resets
primary# sh int po3
port-channel3 is up
Hardware: Port-Channel, address: 002a.6a0a.4caf (bia 002a.6a0a.4caf)
Description: ***Link to FI-B in R18***
reliability 48052/255, txload 1/255, rxload 1/255
Encapsulation ARPA
Port mode is trunk
EtherType is 0x8100
Members in this channel: Eth1/8, Eth1/9, Eth1/10
30 seconds input rate 104 bits/sec, 0 packets/sec
30 seconds output rate 1704 bits/sec, 0 packets/sec
input rate 448 bps, 0 pps; output rate 1.08 Kbps, 0 pps
RX
9070 unicast packets 288523 multicast packets 143322 broadcast packets
440915 input packets 72677230 bytes
7 jumbo packets 0 storm suppression bytes
0 runts 0 giants 36 CRC 0 no buffer
2161727821137838086 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 Rx pause
TX
62914 unicast packets 74425404 multicast packets 14434365 broadcast packets
88922683 output packets 7182753461 bytes
14 jumbo packets
0 Tx pause
17 interface resets
secondary# sh run int po2 mem
!Time: Wed Feb 25 07:56:41 2009
secondary# sh run int po3 mem
!Time: Wed Feb 25 07:58:30 2009
secondary# sh int po2
port-channel2 is up
Hardware: Port-Channel, address: 002a.6a0a.4d6f (bia 002a.6a0a.4d6f)
Encapsulation ARPA
Port mode is trunk
EtherType is 0x8100
30 seconds input rate 1752 bits/sec, 0 packets/sec
30 seconds output rate 1016 bits/sec, 0 packets/sec
input rate 832 bps, 0 pps; output rate 496 bps, 0 pps
RX
76009142 unicast packets 544440 multicast packets 228999 broadcast packets
76782581 input packets 146179423660 bytes
68566412 jumbo packets 0 storm suppression bytes
0 Rx pause
TX
192711593 unicast packets 154928956 multicast packets 31420967 broadcast packets
379061516 output packets 385914168860 bytes
179761364 jumbo packets
0 Tx pause
24 interface resets
secondary# sh int po3
port-channel3 is up
Hardware: Port-Channel, address: 002a.6a0a.4d6a (bia 002a.6a0a.4d6a)
Encapsulation ARPA
Port mode is trunk
EtherType is 0x8100
30 seconds input rate 456 bits/sec, 0 packets/sec
30 seconds output rate 1784 bits/sec, 0 packets/sec
input rate 456 bps, 0 pps; output rate 912 bps, 0 pps
RX
75986748 unicast packets 490267 multicast packets 124569 broadcast packets
76601584 input packets 146159548726 bytes
68566413 jumbo packets 0 storm suppression bytes
0 Rx pause
TX
192585042 unicast packets 190939131 multicast packets 13399201 broadcast packets
396923374 output packets 386206869311 bytes
179761514 jumbo packets
0 Tx pause
24 interface resets
We have removed vPC configuration as we are facing same problem as i said in my previous post
partners
Do let me know if anything else is required from my end
-amit
04-10-2013 08:51 AM
vPC - 2
Three ports on N5K-A
Three ports on N5K-B
Are all these 6 ports connected to single FI ?
I assume FI is in Ethernet end host mode.
04-10-2013 09:23 AM
Yes, FI is in Ethernet end host mode
Following is the connectivity from both FIs to both N5K
Three ports on N5K-A is from - FI-A - Eth1/3,1/4,1/5 - Po2
Three ports on N5K-B is from - FI-A - Eth1/8,1/9,1/10 - Po3
Three ports on N5K-B is from - FI-B - Eth1/3,1/4,1/5 - Po2
Three ports on N5K-A is from - FI-B - Eth1/8,1/9,1/10 - Po3
You want to me create vPC-2 on N5K? if yes then i would like you suggest me which two Port Channel i should take on both N5K
04-10-2013 09:53 AM
This is normal port-channel and you will not have any issues.
If you need a vPC setup where single port channel from FI would be connected to two N5K switches.
Sample topology
FI-A ( 2 ports ) ( PC 2 ) <------ First link to vPC 2 ( N5K A )
<----- Second link to vPC 2 ( N5K B )
You will receive the error if you have connected the second linkt to FI B
Padma
04-11-2013 11:26 PM
Padma, I am sorry to say but I am failed to understand the example you have given above.
I am attaching the diagram the way I have connected my cables from FI to N5K. Kindly guide me based on this
04-11-2013 11:32 PM
Hello Amit,
The current deployment is not an issue. However, if you convert these port channels into vpc on N5K, it would throw error messages as your Port channel 2 / 3 are connecting to two FIs ( devices ) .
In other words, vpc interfaces of a channel ( say ID 2 ) from both N5K should connect to same device ( FI )
Padma
04-12-2013 12:31 AM
Hi Padma,
As per suggestion have made changes on N5k but still facing the same error.
Also want to know that while confiuring vpc it is required that on both N5k switches connections should be same? like in our case FI-A-Port 2/9-11 is going to N5k-A-Port-1/3-5 and FI-A-Port 2/14-16 is going to N5k-B-Port-1/8-10. I hope this should not create problem for me
I am attaching updated diagram for your reference and output of command few commands
primary# sh int po2
port-channel2 is up
vPC Status: Up, vPC number: 2
Hardware: Port-Channel, address: 002a.6a0a.4cac (bia 002a.6a0a.4cac)
Encapsulation ARPA
Port mode is trunk
EtherType is 0x8100
30 seconds input rate 1400 bits/sec, 0 packets/sec
30 seconds output rate 848 bits/sec, 0 packets/sec
secondary# show int po2
port-channel2 is down (No operational members)
vPC Status: Down, vPC number: 2 [packets forwarded via vPC peer-link]
Hardware: Port-Channel, address: 002a.6a0a.4d71 (bia 002a.6a0a.4d71)
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec
Encapsulation ARPA
Port mode is trunk
auto-duplex, 10 Gb/s
EtherType is 0x8100
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
!Time: Fri Feb 27 07:19:14 2009
vpc 2
!Time: Fri Feb 27 07:19:50 2009
vpc 2
primary# show vpc ====== status as below
vPC status
2 Po2 up failed vpc port channel 12-13,21,10
mis-config due to vpc 1-600
partners
secondary# show vpc ====== status as below
vPC status
2 Po2 down* failed vpc port channel -
partners
04-12-2013 01:12 AM
Did you make the change on FI as well i.e single port channel interface having 6 member interfaces ?
Flap the interface at both ends and verify the outcome.
