ā11-10-2016 05:36 PM - last edited on ā03-25-2019 01:40 PM by ciscomoderator
ā11-10-2016 08:32 PM
The easy question of connecting the tape library directly to the UCS FI is no since you're already running the FI in end host mode (relying on upstream fibre channel switch). Cannot directly attach the tape drive -- must go through the switch.
As to passing the drive through to a VM, you will zone the drive to the ESXi servers and then need to configure a SCSI passthru for the device. However I believe you will lose the ability to vMotion the VM once you do this.
Weve left our tape hosts as physical UCS blades to avoid this problem. The easier solution would be to use iSCSI tape libraries and then connect the VM through its normal uplinks to the library.
ā11-11-2016 02:36 AM
The interop matrix
http://www.cisco.com/c/dam/en/us/td/docs/unified_computing/ucs/interoperability/matrix/b_hcl_B_rel3-12.pdf
clearly says
Direct connect of tape libraries is not supported
ā12-10-2016 06:05 AM
ā12-10-2016 11:52 PM
What is your topology; do you have a MDS switch, connecting the UCS FI as well as the tape library ? and if yes, if the FI in FC end host mode ?
As I said before, connecting tape directly to UCS FI is not supported.
ā12-11-2016 01:08 PM
I am not connect tape library directly to UCS fabric.I connect library through fabric swatches MDS.I zoning WWN of two library drive s with WWPN of UCS server's.Its write zoning or I zoning library node name.
ā12-11-2016 01:13 PM
Can you post the output of the following cli commands on the MDS
show fcns database vsan xyz ?
show flogi database vsan xyz
show zoneset vsan xyz ?
show zoneset active vsan xyz ?
ā12-12-2016 03:38 AM
Dear Mr.Walter,
Kindly check uploaded file you ask about.Please i see media changer device for physical library and VTL.But i can't see any driver for both .The same zoning for AIX LBAR and i can see media changer and its drivers.
ā12-12-2016 04:30 AM
If you look at the active saveset, you see many entries like below, where the entry without A (*) means that this device has not done a flogi, and therefore is not reachable.
Walter.
PS. cosmetic issue which has nothing to do with your problem: never use vsan 1 !!
zone name DB2-SRV2_p3_SVC_PG0 vsan 1 * fcid 0x430600 [pwwn 50:05:07:68:0c:12:56:fe] * fcid 0x430b00 [pwwn 50:05:07:68:0c:22:50:bb] * fcid 0x431701 [pwwn c0:50:76:09:11:79:00:08] pwwn c0:50:76:09:11:79:00:09 <===============================
ā12-12-2016 04:42 AM
Please ,you mean i change vsan 1 to another vsan or what i do exactly ?
The second point zoning steps of Library drives with UCS servers are correct ?
Thank you for your assistance and your help.
ā12-12-2016 05:09 AM
I would use any vsan id different from 1, and a different one for Fabric A resp. B. Maybe even number for A and odd number for B.
Unfortunatly fcalias are per VSAN and therefore have to change as well.
Therefore think about using device alias instead ?
When you talk about ....four ucs server wwpn... do you mean ESXi ?
